Repair Install
  1. Posts : 72,052
       #1450
    Hello Jim,
    I'm happy to hear that you are back up and running again without losing anything, but sorry it took a clean install.
    I agree with the other person that helped you. Registry cleaning programs are to be avoided at all cost. There are just to many out there that are nothing more than snake oil that claim to fix everything including the kitchen sing that only cause damage to Windows usually leading to have to reinstall.
    Registry cleaners that are over aggressive in reporting what should be removed from the registry is often the problem. The next problem is the user allowing these results to be deleted from the registry without knowing what is safe or not safe to allow to delete. The program doesn't really help to let the user know what is safe or not, and the ones that do may not always be correct. We all know what happens if you delete something from the registry that shouldn't have been deleted. You'll find yourself with an unstable/crashing Windows and/or other programs.
  2. Posts : 149
    I have run scannow numerous times and each time it tells me it could not repair all the files...
    The only Windows 7 disc set I have is the one I just received from HP....it does not allow for repair.
    Appreciate your help.
  3. Posts : 72,052
       #1452
    Hello Barnum,
    Yeah, that disc set would only allow you to do a factory install of Windows 7.
    You could see if doing the items listed in the blue Note box under step 4 in OPTION TWO if the tutorial below may be able to allow SFC to repair the files afterwards.
    If not, then please post back with your sfcdetails.txt file from OPTION THREE to see what SFC says it cannot repair, and if it's anything to worry about. Are you having any other issues?
  4. Posts : 149
    No other problems...just this long startup.
    This is the message I got when I ran sfc/verify
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Windows\system32> sfc /verifyonly
    Beginning system scan. This process will take some time.
    Beginning verification phase of system scan.
    Verification 100% complete.
    Windows Resource Protection found integrity violations. Details are included in
    the CBS.Log windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log
  5. Posts : 72,052
       #1454
    If you like, go ahead and post back with a sfcdetails.txt file after running a sfc /scannow command, and I'll be happy to see what it says it cannot repair.
  6. Posts : 359
    Windows 7 Professional 64bit
       #1455
    I have a Toshiba C660D but when booting the laptop it gets passed the welcome screen but it then says "windows explorer crashed" and prevents me from doing anything else i.e. No desktop icons load
    It seems like someone turned off the laptop half way through a windows update.
    Spec:
    Toshiba C660D
    Windows 7 64Bit
    Do you recommend a repair install?
  7. Posts : 1,633
    Win 7 Ult SP1/Win 10 Pro (all x64)
       #1456
    Can you boot into Safe Mode and while there, initiate System Restore?
    Lesson #1: Never interrupt Windows Updates, or any update for that matter.
  8. Posts : 10,796
       #1457
    Spec:
    Toshiba C660D
    Windows 7 64Bit
    Do a "system restore" ... eventually from "win7 recovery environment"
    System Restore
  9. Posts : 26
    Try booting up in safe mode and restoring to a previous restore point.
  10. Posts : 62
       #1459
    Could not retrieve information
    Going to do an Install/Repair on a HP Slimline Desktop
    Getting BSOD, with IRQL and others
    Clean of malware
    Could only boot to Safe Mode
    Had to resort to Selective startup settings with nothing checked to boot normal.
    Now boots OK.
    When I go to the install part, get temporary files loaded then:
    "Windows could not retrieve information about the discs on this computer"
    I assume there's some service that needs to be checked but I don't know which.
    Pete
