Repair Install
  1. Posts : 32
    xp , vista
       #1700
    But which files i need to post ?
    Can you give me the name of the files where is logged the reason for fail ?
  2. Posts : 72,059
       #1701
    Any of the ones you have from the MS articled for the installation logs.
  3. Posts : 5
    New Mexico (NM) Windows 7 Home Premium 64bit
       #1702
    Posted on other thread and was helped to this tutorial and got started on repair install.
    Now I am in a pickle and feel like I am drowning. Help would be appreciated.
    Ran repair install following tutorial (I hope I did). Babied it for about 14 hours of stopping and following all instructions, uninstalling things requested and about 4am there was 87% finished with process. By 7am my pc was sitting at password screen for me. Started normal and after looking for the folders for data cleanup, none were found. Update screen came on and said I needed to update the SP1, proceeded, wouldn't install. My guess is install repair didn't work. PC is still acting the same, slow, cd/dvd not reading media.
    Reset everything and started with fresh repair install. Would not let me get pass screen saying I had to install win sp1! Tried several more times to no avail.
    Did a sfc/scannow and it came back to say nothing is wrong in system. Did several more times to be sure. Ran a SURT, and the info is listed below.
    Been reading so many post and trying fixes for the individual problems, I am at a loss as to which way to go from here.
    I am using repair install - Win 7 Home Premium with SP1 U media refresh x17-58997.iso from link on tutorial.
    Checking System Update Readiness.
    Binary Version 6.1.7601.22471
    Package Version 26.0
    2014-10-29 00:51
    Checking Windows Servicing Packages
    Checking Package Manifests and Catalogs
    (f)    CBS MUM Corrupt    0x00000000    servicing\Packages\PA32D9~1.MUM        Expected file name Package_for_KB972270~31bf3856ad364e35~amd64~~6.1.1.0.mum does not match the actual file name
    (f)    CBS Catalog Missing    0x00000002    servicing\Packages\PA32D9~1.cat
    (f)    CBS MUM Corrupt    0x00000000    servicing\Packages\PAE326~1.MUM        Expected file name Package_for_KB972270_RTM~31bf3856ad364e35~amd64~~6.1.1.0.mum does not match the actual file name
    (f)    CBS Catalog Missing    0x00000002    servicing\Packages\PAE326~1.cat
    Checking Package Watchlist
    Checking Component Watchlist
    Checking Packages
    (f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_2_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.mum
    (f)    CBS MUM Missing    0x00000002    servicing\Packages\Package_for_KB2545698_SP1~31bf3856ad364e35~amd64~~6.1.1.3.mum
    Checking Component Store
    Summary:
    Seconds executed: 1591
     Found 6 errors
      CBS MUM Missing Total count: 2
      CBS MUM Corrupt Total count: 2
      CBS Catalog Missing Total count: 2
    Unavailable repair files:
        servicing\packages\PA32D9~1.mum
        servicing\packages\PAE326~1.mum
        servicing\packages\Package_2_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.mum
        servicing\packages\Package_for_KB2545698_SP1~31bf3856ad364e35~amd64~~6.1.1.3.mum
        servicing\packages\PA32D9~1.cat
        servicing\packages\PAE326~1.cat
        servicing\packages\Package_2_for_KB2545698~31bf3856ad364e35~amd64~~6.1.1.3.cat
        servicing\packages\Package_for_KB2545698_SP1~31bf3856ad364e35~amd64~~6.1.1.3.cat
    2014-11-02 16:39
    Checking Packages
    Summary:
    Seconds executed: 1058
     Found 6 errors
    2014-11-07 16:04
    Checking Packages
    Summary:
    Seconds executed: 4032
     Found 6 errors
    2014-11-10 11:41
    Checking Packages
    Summary:
    Seconds executed: 2227
     Found 6 errors
  4. Posts : 72,059
       #1703
    Hello sstdiana,
    I'm afraid that it looks like you may need to do a clean install of Windows instead.
  5. Posts : 5
       #1704
    Aghhhhhhhhh! So did not want to hear that. My dvd is not reading any media and I had to use the usb tool to try the repair install. Can I do a clean install with a usb? I did a download/backup of my c:drive before I started the repair install. If I try to backup to a clean install will any of the messed up stuff transfer back? Trying to decide if I just want a new pc for Xmas and fix this one blank for one of the kids. Thoughts? My pc is my life in this small town and can't be without one. It was bad enough last night while it was trying to repair install. Is it worth it for my particular pc?
    Thanks for replying so fast. I love this sight. I have been able to answer lots of questions.
  6. Posts : 72,059
       #1705
    Yes, you sure could boot from a USB to do a clean install. Since this is an OEM PC that came with Windows preinstalled, the tutorial below can help show you how to. :)
    Clean Reinstall - Factory OEM Windows 7
  7. Posts : 5
       #1706
    Thank you again. I will head that direction and see if that is the direction I want to make.
  8. Posts : 21,004
       #1707
    Ok Shawn am having no end of problems recently the posting of thread replies being the one that is really beginning to irritate me. Now if I go ahead and do this repair is my C: drive going to be filled with a duplicate set of data?? Plus what happens to that System reserved ? partition? and I take it that I should detach the other drives while I do this leaving just the C: drive in??
    I have tried uninstalling IE11 but cannot get it back and resorted to a system restore for that problem. I am hoping this is better than a clean install because I have a lot of data I use all the time on that drive.
    Attached Thumbnails Attached Thumbnails Repair Install-comp.png   Repair Install-comp2.png
  9. Posts : 72,059
       #1708
    Your system reserved partition will not be affected, but you will get a Windows.old folder on C: that is a copy of your current installation that you can delete afterwards.
  10. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
       #1709
    Interesting System reserve wouldn't that be a boot manager :/
    Why it has a drive letter assigned to it is a mystery mine does not ?
    Show your disk management shot.
