#1770
Abyrne,
I think it may be time to consider doing a clean install instead.
Clean Install Windows 7
Abyrne,
Yeah I must say that having done a Repair Install for the very first time in my life this week, I was surprised to learn that it requires a working Windows system to implement!
Abyrne yours seems too badly hosed for this repair method.
In the future you should make image backups of your hard drive to avoid disasters like this.
How can I do a clean install if my laptop won't read DVDs and USBs properly?
Hey Abyrne,
Got a fee questions for you. :)
Did you already check your BIOS settings to make sure it's set to allow USB at boot?
When you created the USB, did you use the method in the tutorial I posted above?
Are you able to user your motherboard's boot menu to select to boot from a USB or DVD?
Ok, thanks for the help so far guys...looks like I'm gonna have to bite the bullet and do a clean install...
Before I do, what is the best way for me to 'transfer' or save my settings, files, programs etc. so I can use them again on the new install? Don't fancy completely starting from scratch, I'm already transferring my music to my cloud! I know you can use Windows Easy Transfer if you're moving to a new computer, anything I can use in this case? Thanks!
Hello mate try this for getting your data back / saved .
BOOTABLE UBUNTU
Make a bootable Ubuntu disk http://www.ubuntu.com/download
Set the BIOS to boot from the optical when the machine boots it will show you a screen with TRY or INSTALL > select TRY not INSTALL
When it is finished - it takes very little time you will get a screen like in the pic .
Open the drive you want > User and dig down until you get to the data / settings you may be able to copy / paste the material you want to an external source or other installed drive doing this.
I am not sure if it will but I have recovered tons of data etc using this method both on "dead" or just plain drives that you cannot get data from using Windows.
This can also be done with a Linux Mint MATE set up but try this first it works in much the same manner. You just have to copy / paste the data to an external but make sure you use TRY
Hi ICIT2LOL, this is superbly clear, much better description than I have seen before.
Just to clarify:
a) Once Ubuntu running, you can remove the Ubuntu disk and replace with an empty disk to download your data, right ?
b) you say "copy and paste": but would that not mean having to open every file and copy each individually ? Is there not a way to just send the whole of e.g. My Documents to the empty disk ?
Sorry if these are daft questions, and thanks again for the explanation, adj
Hiyya mate glad you found it helpful and no - no such thing as daft question if you don't ask you will never find out and as a general rule most of us "oldies" will never criticize your questions - if they are rude or plain idiotic or begging for an argument the you will find they get short shrift but if you think you have been unfairly treated then just hit the report button - but to answer your queries
a) no I have never had to do that but I guess you can try
b) no I just copy / paste whole libraries etc because most important data is usually in pictures or documents - if you did say pictures one by one it would drive you nuts
AS for programs I am not sure because I have only ever needed to retrieve data.
It appears that the Page 1 links to the various W7 iso files no longer work. Although I've not tried it yet, it seems that this page
Microsoft Software Recovery
is only for Retail versions of the software (and not e.g. OEM)?
