Repair Install
  1. Posts : 7
    Windows 7 Home Premium SP1 32bit
       #1790
    This can be done even after the Windows is re-installed. unless the network drivers are missing.
    So, how to ensure the Internet is working?
  2. Posts : 72,052
       #1791
    You could, but it would be better to have them available before in case you do need to install the network driver to be able to connect to the internet.
  3. Posts : 880
    Windows 7 Professional 64bit
       #1792
    Brink said:
    I find that the most reliable way to back up your drivers is to download the driver installation files from the device/PC manufacturer, and save them to another location.
    Which could be another drive within your PC or an external drive i.e. it doesn't have to be a network location.
    Though in my experience W7 will most likely have a built-in driver that will work with your NIC, though it might not be THE BEST or latest one available.
  4. Posts : 7
       #1793
    OK, I went to the Intel website and downloaded the latest (v19.5) Network Adapter Driver for Windows 7 PROWin32.exe file (the 64Bit is also available) and I even tried it. Everything went OK. I have a new set of drivers now and will be able to use it later.
    My system is currently sluggish, moving in slow motion..
  5. Posts : 72,052
       #1794
    You may have Windows Updates installing in the background. Double check to make sure that they are all installed and then see how your system is performing. Hopefully well.
  6. Posts : 7
       #1795
    I have already install the latest updates - it took three reboots!
  7. Posts : 72,052
       #1796
    If it was sluggish before doing a repair install, then you may need to do a clean install instead. Otherwise, you could go through the items below to see if it may help with performance.
    Optimize Windows 7
  8. Posts : 21,004
       #1797
    I found that interesting re the driver back up stuff so is there any particular software besides Driver Reviver available to do that because all I ever do is image weekly and to pick the eyes out of one for drivers would be tedious.
    I say that only because if I were using the image to reinstall with because of some major infection I couldn't get rid of I would be loathe to use the image.
  9. Posts : 880
       #1798
    ICIT2LOL said:
    I found that interesting re the driver back up stuff so is there any particular software besides Driver Reviver available to do that ...
    DoubleDriver seems to do a very nice job:
    BooZet Freeware
    Just "Scan current system" and it defaults to non-MS drivers checked. Backup Now to anywhere you'd like.
  10. Posts : 21,004
       #1799
    BooZet Freeware
    Ok Max will try it out the Driver Reviver was pay for as far as I could see and with five machines is a costly exercise unless it is portable.
