Repair Install
  1. Posts : 72,050
       #2040
    A repair install will only leave you with the same as what you have installed now.
  2. Posts : 135
    Windows 7 Ultimate 64
       #2041
    Brink said:
    You would if the ISO was the same or newer build than what you currently have installed.
    Sometimes it may not be so easy to uninstall SP1 since there were so many updates afterwards.
    I think I may not have been clear as to what I was asking. Let's take a hypothetical. Let's say I get a Windows 7 ISO file, and it is NOT as recent a build as what I have now. And let us suppose that I CAN successfully remove (uninstall) SP1. Would that not leave the ISO file later than what I have (since the ISO file has SP1 and what I have would NOT have SP1 after I uninstalled it. Now, assuming that I could do all of that (which I understand is by no means certain), would a Repair Install then bring me back to whatever version was on the ISO file, AND leave my existing applications intact (Understanding that I would then have to run Windows Update to update whatever was updated between what I started with, and what the ISO file had)?
    Two other questions for you. Since this would be a fairly risky move, should I choose to try it, let's say that I make a System Image before I begin. And let's say that for whatever reason, the Repair Install fails. Could I not then restore my System Image, and be back to where I am today (admittedly, with the same problems regarding Windows Update that I have now)?
    And one probably minor question regarding the Repair Install itself. As I recall, there was a statement that the system would reboot several times during the Repair Install. That being the case, would one need to remove the DVD or USB stick that has the ISO on it to prevent booting to that, rather than whatever stage of the installation process we were at at the time? Or would the installation process be smart enough to figure out not to start over from the boot DVD/USB?
  3. Posts : 72,050
       #2042
    Answers inline. :)
    Yes, but only if the ISO was the same or newer and if you were able to successfully uninstall SP1 without causing more issues.
    Creating a system image before you start would be a smart thing to do. Normally if a repair install fails, it'll automatically revert back to how you were before you started. However, it'll be safer to have a system image as a backup incase something went wrong with the repair install preventing it from automatically reverting back.
    You should be fine if you use a USB, but it would be better to have the ISO on a hard drive instead.
  4. Posts : 135
       #2043
    Brink said:
    Answers inline. :)
    Thanks. On your last point, somewhere I got the notion that to do a repair install, that I had to boot from the install media (no doubt an error on my part, since I have read so much lately on various approaches to solving this problem.) But if I can run the ISO directly from a hard drive, that would be easier than creating a boot device. Can you run an ISO file from a hard drive? Shows you how much I know about ISO files.
    You have been very patient and helpful to me. I'll have to give this all a good bit of thought before I decide what to do. I've been planning on buying a new computer eventually (mine is over 6 years old) with Windows 10, so this may be the time to bite that bullet. But even if I do, I'd still like to get the old machine in good working order and maybe use it as a backup. Of course, if I do that, I'd have moved or reinstalled most everything to the new computer, so reinstalling Windows from scratch (even from the Dell DVD) would be a more sensible option. Thanks again for your help.
  5. Posts : 72,050
       #2044
    You're most welcome. Please let us know how it went. :)
  6. Posts : 16,160
    7 X64
       #2045
    "Can you run an ISO file from a hard drive?"
    Yes,if you are using bios firmware (you obviously are ).
    Set it up with Easybcd.Scroll down this link to get the free community edition:
    EasyBCD - NeoSmart Technologies
      My Computers
  7. Posts : 7
    Windows 7 Home Premium 64 bit
       #2046
    so in the section where to extract a iso window file you have a E volume i dont have extra volumes on my computer and my D: is full mostly of recovery stuff even if i wanted to use it. so should i created a new volume on my laptop i have 464 gb free of 575 gb on my C:
    and the part where it says check if user files are missing after the install repair, do i just check back and forth between the new files and old files that would seem like a lot of files and folders to look through or did you mean personal files or files in the actual folder named "USER"
  8. Posts : 72,050
       #2047
    Hello Kenny, and welcome to Seven Forums. :)
    If you have a USB flash drive, then you could extract the ISO to it to use. A 4-8 GB USB flash drive is pretty cheap these days.
    Usually, you won't have an issue with missing user files, but you could just look in the copy of your user profile folder inside the C:\Windows.old folder to see if anything is there.
  9. Posts : 7
       #2048
    oh ok so using a usb flash drive is better than creating another volume on my laptop to use?
  10. Posts : 72,050
       #2049
    It's easier to use a USB, but either way works.
