Repair Install
  1. Posts : 72,055
       #2070
    Caramelo said:
    Ok, that's good to know. Thanks. I dl a Win7 SP1 ISO from the link on the first page of this thread. Hopefully I won't have trouble with entering the product key of my OEM Win 7. When I tried to get an SP1 ISO from the MS site it would not let me download it and they told me the key was from an OEM and to go see the pc manufacturer. I built it myself
    Another question; If I'm unsuccessful in having a repair install fix the problems I'm having is it possible to upgrade the Win 7 to Win 10? Does the install of Win10 depend on a completely healthy win7?
    Caramelo,
    Sorry, I didn't see your update to the post.
    If the Windows 7 is activated, you will be fine. In you like, you could also just clean install Windows 10 and use the Windows 7 key to activate it.
    Clean Install Windows 10 Directly without having to Upgrade First - Windows 10 Forums
  2. Posts : 72,055
       #2071
    kenny lc said:
    I had the repair install done and almost everything is fine, i have my programs and personal files. i only have 3 problems. my computer is running a little slower than before, i cant download updates it just checks forever and ever and never stops and my internet explorer is 8 now instead of 11. i figure the internet explorer issue is because i cant get the new updates to get ie11. i tried a manual install of a update and that ran forever and ever too.
    Hello Kenny, :)
    Windows 7 has been having issues with Windows Update lately. You might see if this below may help you as well.
    Windows updates stuck at 0% forever
  3. Posts : 81
    Windows Home Premium 64- bit(6.1,Build 7600) SP1
       #2072
    Thanks for the input Kenny. I've experienced similar problems with updating windows both automatically and manually. It seems stuck in an endless loop. It's curious why a repair install would cause that to happen. I've read other accounts of it occurring though.
  4. Posts : 7
    Windows 7 Home Premium 64 bit
       #2073
    yeah it did need to download the files first, i had my settings to download files and choose whether to install and later it had 226 updates to install with 8 optional. internet explorer 11 was one of the optional 8. i'm installing the updates to see if that helps get things completely back to normal.
  5. Posts : 81
       #2074
    I'd be interested to know if you can get it all back to normal. I might need to do a repair install myself because I keep getting certificate validity problems when trying to install some net.framework components.
  6. Posts : 7
    Microsoft Windows 7 Home Premium 64 bits 7601 Multiprocessor Free Service Pack 1
       #2075
    I'm stuck at step 12. The program complains of several compatibility issues. Some I could fix, but with others I don't know what to do. These are the ones I fixed:
    • Network adapters: Surf Wireless Micro USB Adapter.
      Updated driver, fixed.
    • Network adapters: Realtek PCIe GBE Family Controller.
    • Compatibility issues with iTunes.
      Uninstalled it, fixed.
    And these the ones that keep me stuck:
    • VNUSB Device: VN Series Device.
      Don't even know what to do with this.
    • System devices: Intel(R) Management Engine Interface.
      For this one and the next one I installed the Intel Driver Update Utility. However, the utility says all my drivers are up to date.
    • System devices: Intel(R) 6 Series/C200 Series Chipset Family SMBus Controller - 1C22
    • Image devices: HP Deskjet 1510 series (USB).
      This is my printer/scanner. For this one and the next I installed the last driver from HP, but the installer still complains.
    • Universal series bus controller: HP Deskjet 1510 series(REST).
      It's funny that this is listed as a USB controller. Might be related to the problem?
    Any suggestions?
  7. Posts : 72,055
       #2076
    Hello Alonso, :)
    If able, you can continue with the repair install if you like. It just means that you may or may not have to reinstall those drivers afterwards.
  8. Posts : 7
       #2077
    Thank you for the advice. I did continue with the install repair in spite of the warnings and it kinda worked, but with a lot of problems. The main one is that Windows Update doesn't work now. I'll explain in detail everything I did. Probably most of it is irrelevant, but I include it in case it helps clarifying the problem:
    Started the repair install and kept using the PC for some other stuff in the meantime (hope this didn't cause problems). At some point the installation tried to restart the computer, but couldn't do so because I had some files open. Closed my files and restarted the computer manually.
    From that point the screen went blank for hours. After a few hours I saw that the computer had entered sleep or hybernation or something similar (orange light in the power button) so I started it, hoping that the screen would finally show something. It didn't, and, again, after some time, the computer hybernated. I started the computer again, same thing again, repeated a few times until eventually the monitor showed the Windows login screen.
    Logged in, activated Windows and went straight to Windows Update. Windows Update searched for a few hours and eventually returned an error code saying it couldn't update anything (didn't write down the code). Restarted the computer and had again the problem of blank screen -> hybernate -> turn on several times until the monitor worked.
    Tried Windows Update again and this time it doesn't return any error, it just stays stuck there looking for updates (it's been about 14 hours now).
    Apart from that, I am trying the repair install because the computer has a number of problems. The most important one is that the CPU usage is always high, even when the computer is idle. That problem remains.
    Also, I use a time tracking tool called ManicTime which has stopped working since I did the repair install.
    What can I do?
  9. Posts : 72,055
       #2078
    It sounds like you may need to do a clean install instead.
  10. Posts : 4
    windows 7
       #2079
    thanks i followed it and it work very well..thanks man keep it up...:)
