Repair Install
Page 11 of 218 FirstFirst ... 91011121321111 ... LastLast
  1. Posts : 34
    Windows 7 64bit
       #100
    Oh Well
    I have been preparing myself for this ever since the Windows Media
    Center fiasco... I appreciate all the attempts to recover.. I've been running with the RTM build from MSDN. Guess I'll wait for the 22nd
    release and install that one.. Thanks for all your help and patient.
  2. Posts : 7
    Hello Brink,
    My Windows 7 x64 upgrade is activated. Is there anything I should do differently?
    Thanks,
    T.
  3. Posts : 72,049
       #102
    Hello Travelin,
    I'm not sure what you mean, but you can still do a repair install if your Windows 7 is activated without having to do anything different.
  4. Posts : 7
    Shawn,
    In Step 12, you say to uncheck the Automatically activate Windows when I'm online box. I was curious if I should check or not check this box, or perhaps, since my Windows 7 is already activated, that will not appear.
    Thanks,
    Paul
  5. Posts : 72,049
       #104
    Oh, ok. Yes, it will still appear during installation, and you will need to activate again after the install as well.
    I recommend to always leave that box unchecked, so instead of Windows 7 trying to automatically activate in 3-days, you can have 30 days by default to activate manually in case you wanted or needed to activate later than 3 days. That's all.
  6. Posts : 7
    Thanks, that's what I was curious about, whether Windows 7 will need to be activated again.
  7. Posts : 72,049
       #106
    You're welcome. :)
  8. Posts : 285
    Very nice tutorial Brink!
    I have one question, if you have a activated version of Windows 7, why should you activate it again after the Repair Install upgrade?
    Kind regards,
    zx81
  9. Posts : 72,049
       #108
    Hi zx81,
    Anytime you install, you will have to activate. It's just Microsoft's way of making sure that you are not a Captain Blackbeard pirate. That's all.
  10. Posts : 4
    Win 7
       #109
    This is great what if you cannot boot into Win 7 in the first place? Then how do you do a "repair"?
    In XP, you can boot up from your XP disc, go thru the various prompts and eventually select "repair install". Is this possible with Win &?
    Thanks.
