Repair Install
  1. Posts : 26
    Hi Brink,
    Thanks for your help and clarifications.
    That part of the warning is just to let you know that you can use a retail ISO to repair install an OEM installation since you can't use OEM factory recovery media to repair install.
    and
    "You can use a retail Windows 7 SP1 installation disc (ex: Technet (available), MSDN (available), or retail (when available)) to do a repair install with on a currently installed Windows 7 SP1."
    So my MSDN ISO/ DVD is equivalent of a Retail DVD in my scenario and can I use it for repair my OEM?
  2. Posts : 72,052
       #2131
    Correct, it's the same as a retail version and can be used as long as it's the same language, edition, and version or higher as what you currently have installed.
  3. Posts : 26
    "same version or higher"?
    How a Microsoft ISO or DVD (5/6 years old) can be the same version or higher than a current, installed up-to-date Windows 7 x64 SP1 (6.1.7600600385)?
    It would be surely older than that current release...
    It can only be same version or lower.
  4. Posts : 72,052
       #2133
    That's the potential issue with an older OS.
    It won't hurt to try the repair install since it will only fail and revert back if not successful.
  5. Posts : 26
    Ok clear.
    Another question, please.
    Currently the HD where Windows 7 x64 SP1 Ultimate is installed also includes another partition with Windows XP.
    So booting the PC, there is the Boot Manager showing for a few seconds:
    Windows XP
    Usually I simply press enter when the Windows 7 is selected or after a few seconds automatically Windows 7 starts.
    Will this Boot Manager setting be an issue for this Windows Reinstall on place?
  6. Posts : 16,162
    7 X64
       #2135
    Up to date version is currently 7601.24168
    7601 is the build. You will have difficulty getting 7600 ( non SP1) media to perform repair install.
    24168 is the service build. That doesn't seem to cause any problems for repair install.
      My Computers
  7. Posts : 26
    Hi SIW2,
    What do you mean for:
    7601 is the build. You will have difficulty getting 7600 ( non SP1) media to perform repair install. ?
    Using the Winver command I am getting:
    Version 6.1 (Build 7601: Service Pack 1)
    My ISO /DVS actually includes the SP1 so I am not sure about your post.
  8. Posts : 16,162
    7 X64
       #2137
    My ISO /DVS includes the SP1.
    You would have difficulty trying to use non SP1 ( 7600) installation media.
    Your media contains SP1 (it is 7601) your current installation is also 7601, so should be fine.
    You will have a lot of updates to get afterwards, and you will also need to reactivate ( so have your product key handy).
    The repair install should retain your existing boot menu entries.
      My Computers
  9. Posts : 26
    Ok, so then I am ready. Thank you!
    Backup with 3rd party software has been done with boot CD available.
    Also I save Windows desktop icons positions.
    Let's keep fingers crossed!
  10. Posts : 16,162
    7 X64
       #2139
    Turn off your a/v. I always do - not sure if it strictly necessary.
    I have lost count of the number of repair installs I have done - it is a useful feature. It can take quite a while if you have a huge number of programs installed.
      My Computers
