Repair Install
  1. Posts : 26
    Another strange issue is about one third of my applications appears to be all installed in August 21st 2018 under the Windows Control Panel, so they lost the original date installation. The other 2/3 kept the original dates.
  2. Posts : 137
    Windows 7 Ultimate 64-bit SP1
       #2161
    Seven months of smooth sailing since my repair install of Windows 7 Ultimate. I bought the Macrium Reflect license for up to four computers to help too. Thanks again. This tutorial saved me so much trouble.
  3. Posts : 72,058
       #2162
  4. Posts : 7
    multiboot:XP Sp3, Win7 pro, Win7 Home premium (not booting)
       #2163
    with multiboot
    Thanks for this excellent tutorial on doing a "repair install". One thing I didn't find was if I can "repair install" one win7 install while booted to another win7 install on a multiboot 'puter. I have XP sp3, win7 Home Premium, and Win7 Pro. The Home Premium went kaput, the XP and Win7 Pro are still fine. I'm looking to do a "repair install" on the Home Premium. It will not boot (missing or corrupt hal.dll). Thanks
  5. Posts : 16,163
    7 X64
       #2164
    No.
    Need to boot into the sick OS to do a repair install.
    You can try a system restore, or a clean install.
      My Computers
  6. Posts : 7
       #2165
    Ok, thanks SIW2. If I could boot into it I wouldn't need a "repair install".
  7. Posts : 96
    Windows 7 Professional 64-bit
       #2166
    This thread hasn't had any activity in over a year. Still, I just did a Windows 7 repair install & I documented some things I thought might be of interest or usefulness to others. I don't know if any of what I've posted duplicates something in this thread. It's 55 pages of stuff going back about 11 years. I'm not quite so idle that I can read through all of that. But here's what I did. Yours to decide if it's fluff, noise, or contribution.
    Repair install from HDD
  8. Posts : 132
    Dual boot - Win 7 Pro 64-bit and Win 10 Pro 64-bit
       #2167
    Can I repair Win 7 Pro 64-bit if I can't start it?
    My Dell Optiplex 7010 MT dual-boots Win 7 Pro 64-bit and Win 10 Pro 64-bit. The Win 10 starts, but the Win 7 doesn't. The Win 7 gets as far as the four glowing MS flags but no further (although they continue to pulse and glow, forever).
    Is there a way to repair my Win 7 Pro 64-bit while preserving apps and files, maybe using the method here?
    If not, if I boot up into my Win 10, is there anything I can then do to fix/repair the Win 7 while preserving its stuff?
    If not, then WHAT FOR GOD'S SAKE????
    Thanks.
  9. Posts : 16,163
    7 X64
       #2168
    did you integrate the nvme updates into your win7 installation ?
      My Computers
  10. Posts : 132
       #2169
    SIW2 - Not recently, and I doubt I did it before. But the problem right now is that I can't start my Win 7 in my original HDD. In fact, earlier this morning I removed the new NVMe and re-ran Macrium's Fix Boot problems so that my PC now sees only the HDD.
    My first goal is to repair the Win 7 in my HDD before I do anything else. Any ideas?
    - - - Updated - - -
    SIW2 - As I just commented to your similar reply in TenForums, I might need to put my BIOS back to where it was before I modified it this past week, see if my Win 7 will now start, and then install the NVMe drivers to the Win 7 before re-doing the BIOS modification.
    1. Your post above has a link to https://www.sevenforums.com/attachme...me-win7x64.zip , which has two .msu files. Do I need to run both?
    2. Are there any others I need to run to put NVMe drivers into my Win 7?
    3. Your post above also has links to USB3, DISM and nt6repair9x86 zips. Do I need to understand and run those also?
    Thanks !!!!!
