#150
Hello Stasioau,
Thank you for your kind words.
All retail copies of Windows 7 come with a 32-bit and 64-bit installation DVD. You might double check to make sure which one you have installed and which installation DVD you are using. It's not hard to overlook this and get them mixed up by mistake.
System Type - 32-bit (x86) or 64-bit (x64)
