#160
Absolutely. It all functions as explained in the guide. Each step completes until it gets to this screen (first attached image) and it stalls a 0% for many seconds then presents the next screen that (second image) sends me back to square one.
So I get the latest updates (there are none, even on a second enquiry) and try it again, and the cycle repeats... with the odd exception of this third screen (3rd attached image).
But the truth is, nothing ever gets changed. It just cycles endlessly.
Oh, and the ONLY resource file I've hacked is imageres.dll so I could change the intro sound when logging in, which I assume should have no effect on the upgrade.
SFwriter,
Modified system files could cause unknown issues. If you are able to, run a sfc /scannow command, then see if you can do the repair install after it finishes and you have restarted the computer.
If not, then you may need to do a custom install instead. This way everything in this installation will be placed in a C:\Windows.old folder in the new clean installation.
This is the answer I was afraid of getting... Losing all my settings and installs. I actually did do the sfc /scannow in an elevated command box and it "repaired" my imageres.dll file before I did this, and it had no effect. I'll do it again just to be sure, but as the Great Psychiatrist once said "Insanity is defined by repeating the same actions over and over again whilst expecting a different result".
I'll edit this and apprise you when done.
Results: Lots of files "repaired"; only irreparable ones in the CBS.log are lots of license.rtf and these four, several times over. I edited the 12,000k file down to 56k by removing the licence.rtf references, so I'll append that .txt file so you can have a look.
dot4prt.inf_loc
ir_end.wav
corperfmonsymbols.ini
msdtcVSp1res.dll.mui
Ran set up again, it did the compatibility (first image) thing again, then it copied the windows files (second image) and then stalled again (third image).
So, does any of this help, or do I have to do the complete re-install?
If I remember correctly, scf/ scannow will place a brand new copy of a "corrupted" file in the proper folder, but it doesn't remove the original "corrupted" one... for instance, if you modified your system to run custom start orbs, you'll still have the original imageres.dll.old, plus the one you changed to run custom start orbs imageres.dll.old(2), plus a brand new imageres.dll file from the sfc/ scannow. You may be able to avoid running the complete new install by manually removing the old copies of any files that scf/ scannow replaced. Sometimes the multiple copies of a modified file seem to "confuse" Windows.
(Jeez... that was confusing... I hope you can figure out what I am saying..)
I'll certainly take a peek. Every time I run SFC it says it is replacing corrupted files. Even after I JUST ran it... Maybe it's not replacing anything, just adding new files.
Addenda:
No sign of any folders with the .old added. Seems to be just a single copy of each replacement in the appropriate locations
In addition, you can extract the original files from your Windows 7 installation disc to use to replace them with in your current installation.
Extract Files from Windows 7 Installation DVD
Since coming to the awareness that SFC says it's replacing files every time I run it, that makes me think that not much is really changing... I guess I'm going to have to do the re-install. At least I'll be able to install hardware and software again. (I hope). I'll let you know what happened.
Had to do a complete reinstall, but at least it works now. I can install programmes and hardware once again. And the new web-camera that started it all? I plugged it in and it worked without software, as advertised.
SFwriter,
I'm happy to hear that you got it all working again. Sorry it took a clean install to do so.
