Repair Install
Page 27 of 218 FirstFirst ... 17252627282937127 ... LastLast
  1. Posts : 12
    win 7
       #260
    well i did the custom install, and i am currently working on reinstalling all my apps. thanks a million brink.
    im a little confused about step 18. is there a way to scan both and see the results side by side to see if i'm missing anything? otherwise how? line by line?
  2. Posts : 72,055
       #261
    Cmegalodon,
    Unfortunately, the only way is to compare the user folder contents file by file to see if you are missing any files. You can open two Windows Explorer windows and move them side by side to make it easier to compare though.
  3. Posts : 12
    win 7
       #262
    is it only the "user" folder? sorry for all the questions.
    Brink said:
    Cmegalodon,
    this one.
    one more here. sorry. i cannot find either $windows.~q or $inplace.~tr in the c:\\windows.old. i can only find them in my new c:\\(local)
  4. Posts : 13,354
    Windows 7 Professional x64
       #263
    The Windows folder is not saved. Program Files and User folders are it.
  5. Posts : 12
    win 7
       #264
    well everything is done, and my system appears to be running as smoothly as the day i installed it. thank you thank you thank you.
  6. Posts : 72,055
       #265
    That's great news Cmegalodon. I'm happy to hear that all is ok now. :)
  7. Posts : 2
    Windows 7 Home Premium
       #266
    Hi all, i have some problems with my Windows 7 Home Premium and i think i need to repair my installation.
    I tried to run the System File Checker but it doesn't work.
    I am not able to install 1 update and some minor malfunctions occur daily.
    I don't have any backup point for the OS and although i don't get BSODs, i'd like to fix things without a clean install.
    So i would like to try the procedure on page 1.
    From what i understand, installed programs (Office, camera software, router program, games, ecc) should work normally after this procedure, am i correct?
    Thanks in advance.
  8. Posts : 13,354
       #267
    Thanks in advance.
    Yes, that is correct.
  9. Posts : 2
       #268
    Thanks in advance.
    Thanks, i will proceed right now.
  10. Posts : 5
       #269
    Process Gets Stuck! HELP!
    I followed your instructions.
    At step 10 - after restarting due to conflicting software - the process hung at 18%. The message below the process bar, kept switching from extracting file xxx of xxxx and Windows must restart - but never did restart.
    I have tried several times (having to do a system restore to get restarted).
    Help!!!!!
    Please.
