Repair Install
Page 31 of 218 FirstFirst ... 21293031323341131 ... LastLast
  1. Posts : 72,050
       #300
    Hello Alex,
    No, you will not need to reinstall any of your programs. They will be carried over to the new upgraded installation. Sometimes you may need to reinstall a driver though, but you can see more details on this in the yello TIP box at the top of the tutorial to better help.
  2. Posts : 43
    Windows 7 build 7600
       #301
    Thanks for the speedy reply!
  3. Posts : 72,050
       #302
    You're most welcome Alex. :)
  4. Posts : 6
    Win7
       #303
    That's great man. It worked perfectly. Thank you so much.
    I have a question about it. Could we use this instead of clean install all the time? Are there a downsides or disadvantages of this?
  5. Posts : 72,050
       #304
    You're most welcome Tyler.
    A repair install is only meant as a last effort to repair your current Windows 7 installation. It is not a substitute for a clean install if you wanted to start with a fresh clean formated installation.
  6. Posts : 8
    Windows 7 Home Premium
       #305
    Sorry if this has been asked before, but I'm too hot and bothered to read through the whole post. I have a partition on my disk which is called "recovery" and which contains a folder called "recovery" (wow) which I cannot open. On trying, I get a message from HP saying "this area of the hard disc... contains files used for a system recovery". I'm assuming this is for a clean or repair install? I think I may have created something of the sort in the early days, but I can't remember. Amnesia seems to run in my family.
    And if so, how do I run a repair (or clean install) from the disc, since I can't open it? *bangs head on screen*
    Additional: I'm going to try to revert to a system restore point, but I doubt it'll work. Pessimism also runs in my family.
  7. Posts : 11,408
    ME/XP/Vista/Win7
       #306
    You need to check the manual,but must OEM are press F11 at start up.
    HP Recovery How to.
    http://h10025.www1.hp.com/ewfrf/wc/d...&product=18703
  8. Posts : 8
       #307
    Tried F11 - I get a prompt for an installation disc (and I ain't got none).
  9. Posts : 11,408
    ME/XP/Vista/Win7
       #308
    Did you not make the Recovery DVD's when you first startup for the first time.
    How to order Recovery DVD's
    http://h10025.www1.hp.com/ewfrf/wc/d...name=c00810334
    You may like to start your thread, with the details of the problems you have.
    Windows 7 Forums - FAQ: Board FAQ
    https://www.sevenforums.com/general-d...-ask-help.html
    https://www.sevenforums.com/tutorials...en-forums.html
    Screenshot tools.
    Screenshot with Paint
    Screenshot and Upload using MWSnap
    Fscapture free download
  10. Posts : 8
       #309
    oops!!! - HP Customer Care (United States - English)
    No, I didn't make any. Yes, I'm an idiot.
    Thanks for that link - I didn't know you could do that without bringing in the guarantee (which I've... misplaced; we already established that I'm an idiot). :)
