#340
Brink - I am hoping you can help me out here. My laptop is in an unbootable state - it is BSODing and my system restore restore points have disappeared. My backups of those restore points are too old to be of much use.
I can't tell from your instructions (which are excellent btw) whether or not the "Upgrade Repair" can be run if your machine isn't bootable. In other words, let's assume that I get a fresh copy Windows 7 installed on a another disk or partition on the machine with the problem OS. Can I direct the upgrade repair to repair the OS that's broken? I went through the process but there's no point where it asks you which OS you want to upgrade - I think it simply assumes that it's the one you're running.
Any help MOST appreciated - I am really trying to avoid a total system wipe here.
FYI, I have a raw copy backup of the entire drive prior to anything we do so dont be afraid to try something daring.
Thank you!!!
