HomeGroup Desktop Icon - Add or Remove
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 18
    Windows 7 Professional
       #20
    OK. Thank you again for your help
  2. Posts : 72,058
       #21
    You're most welcome. :)
  3. Posts : 19
    cogeco
       #22
    cool it worked, not sure why lynda had problems, worked right away for me using winrar right click on reg file then merge at destop, thanks a lot blink
  4. Posts : 72,058
       #23
    You're welcome Corduroy. :)
  5. Posts : 74
    The HomeGroup icon appeared on my desktop in a somewhat scary way: after I ran Rootkit Revealer (which BTW didn't run well, as reported here). I can't determine a cause-effect relationship here. The icon has never been there before. AAMOF, if I ever wanted to put it there on purpose I wouldn't know how...
  6. Posts : 72,058
       #25
    Hello Paul,
    Did you create or join a Homegroup recently, or installed one of these all in one utility programs that may have had an option to add this that was mistakenly enabled?
  7. Posts : 74
    Brink said:
    Hello Paul,
    None of the above, but I have TuneUp Utilities 2010 installed since January and never found any way I could add that icon with it. The .reg file provided here removed the icon from the desktop. I remember I created a home group some months ago, but the icon didn't show then.
  8. Posts : 72,058
       #27
    Not sure why it apeared out of the blue like that, but I'm glad you were able to get rid of it.
  9. Posts : 1
    Windows 7 Ultimate
       #28
    Hee, thank you so much for this tutorial! The icon really began to annoy me, especially because it always showed up in the left bottom of the screen while I had put it more up to fit it right with other icons! I suppose the removal tool only removed the icon and not particular important data or the functions of the HomeGroup?
  10. Posts : 72,058
       #29
    You're most welcome Danielle, and welcome to Seven Forums. :)
    No, it only removes the icon and not any of the Homegroup features or functions.
