How to Change Regional Language Format in Windows 7 and Windows 8
InformationThis will show you how to change the format language Windows 7 and Windows 8 uses to display dates, times, currency, and numbers and measurements in your user account so that it matches the standards for the language used in the country or region you need them as or where you're currently located.
Here's How:1. Open the Control Panel (icons view) in Windows 7 or Windows 8, and click/tap on the Region and Language (Windows 7) or Region (Windows 8) icon.That's it,
2. Under the Formats tab, select the format language from the drop down menu that you want to have the dates, times, currency, and measurements formats display with the default standards for that language. (see screenshot below) 3. If you like, you can now change the date, time, currency, and numbers format settings to customize how you like.
NOTE: For Windows 8, see also: How to Change Date and Time Format in Windows 8 and 8.1
4. When finished, click/tap on OK. (See screenshot above)
Related Tutorials
- How to Change Time Zone in Windows 7
- How to Change Time Zone in Windows 8
- How to Change Date and Time in Windows 7
- How to Change Date and Time in Windows 8 and 8.1
- How to Change Date Format in Windows 7
- How to Change Time Format in Windows 7
- How to Change Date and Time Format in Windows 8 and 8.1
- How to Change Numbers and Measurements Format in Windows 7 and Windows 8
- How to Change Currency Format in Windows 7 and Windows 8
- How to Restore Default Regional Format Settings in Windows 7 and Windows 8
- How to Change Language for Non-Unicode Programs in Windows
