WinDBG - Install and Configure for BSOD Analysis
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 17,322
    Win 10 Pro x64
       #30
    What about cut/paste?
    Try to take ownership of just that file if that doesn't work,
    Take Ownership - Add to Context Menu in Windows 10 - Windows 10 Forums
    You do need to move it before opening it.
  2. Posts : 4
    Windows 10 Professional x64
       #31
    When I said I could not read or copy the file, I also meant that cut/paste is not allowed. If you can imagine a procedure on Windows that requires reading a file, then I cannot do it with that .dmp file. Even in safe mode. Even after installing your reg fix that puts "Take Ownership" in the context menu (I used the "pause" version to insure that the action was successful. It says it was successful yet I still lack permission to read/copy/move/open this .dmp file.) The "Take Ownership" function in the context menu does not seem to work at all on this .dmp file. I will continue trying to get at this file. I do not understand why an Administrator account has such limited permissions in Win10 compared to Win7. (I skipped Win8 so I cannot comment on that.)
  3. Posts : 17,322
    Win 10 Pro x64
       #32
    Run this tool,
    BSOD - Posting Instructions - Windows 10 Forums
    It will create a folder on your desktop with the dump in it. (Along with other files)
  4. Posts : 4
       #33
    Thank you! It worked! I can access the .dmp file now. Is there a command I can enter in the command prompt to grab the files from C:\Windows\Minidump like that tool? Does it take ownership, or just circumvent permissions entirely?
  5. Posts : 17,322
    Win 10 Pro x64
       #34
    You're welcome, I'm not sure what the command would be, I know it elevates to admin privileges, and then copies from root to desktop.
  6. Posts : 8
    Windows 7 Professional 32bit
       #35
    I installed the debugging tool in a non-system partition (E) as my system partition is almost full, and downloaded the symbol (Retail_x64) package as well. But when I run the test fill, I always get the "win32 error 0n193" error. I searched online but only find I should use a "correct debugger". I have also tried to follow the official instruction at https://support.microsoft.com/en-us/kb/315263. What's strange, the cd command does not even let me go into partition E. Nothing works out so far. Any idea?
  7. Posts : 21,004
       #36
    Don't know if you have this but it is a very handy site to have for debugging
    Driver Reference Table (DRT) I keep it in the favourites bar for east access - oh and there is a stak of other info on this site
  8. Posts : 21,004
       #37
    Colin just had to reinstall my Toshiba and one of the usual set ups is this tutorial.
    Now I installed the original Pro version back on and I am not complaining but the dump when I click on it comes up instantaneously whereas the other machines have Debuggy not working or something similar flashing for a while would the Pro version be the reason for this. Like I say I am not complaining and I wish all my machines were as quick any thoughts??
    PS the onlyother difference between thismachien and the others is that ithas the Samsung 850 Pro while the others have the 850 EVO.
  9. Posts : 21,004
       #38
    Hello Colin mate I have installed this on my 10 machine and it has worked ok until tonight when it suddenly stopped "debugging" have run sfc and rebooted etc but still the program crashes at the initial screen before analyse-v comes up - reinstall??
  10. Posts : 21,004
       #39
    Hello Colin I found this site in my travels do you think it is of any use please
    [REMOVED]
    There is not only error codes here but references to DLL files etc etc
