Shortcut Arrow - Change, Remove, or Restore
Page 16 of 35 FirstFirst ... 6141516171826 ... LastLast
  1. Posts : 72,075
       #150
    powergeeks said:
    I don't know if this is obnoxious or rude, and I apologize if it is either!
    But, when I wanted to get rid of the arrows, at least for the non system applications, and even then, for some of them at least, I found the actual .exe in the program files folder/ Windows folder respectively. Copy, paste onto the desktop, and there I had it.
    It wasn't a shortcut anymore, but still pointed to the same program, and read the same files to do so. I can't get it for a Computer icon, but that was it. A lot more simple than a utility or reg editing in my opinion.
    I hope this helps, or at least invokes some thought. And I really hope this wasn't brought up previously...
    Hello Powergeeks, and welcome to Seven Forums.
    You are only copying the .exe file to the desktop, so this wouldn't be a shortcut. It is also not recommended to do this since most programs will not run like this. Most programs will have other files in it's C:\Program Files folder that are needed to be in the same location as the exe file for the program to run, and runing the .exe file by itself like that on the desktop will not always work.
  2. Posts : 3
    Windows 7 Ultamate x86
       #151
    Really? I've never had this problem. I've done it for ages on a number of computers. Huh. Thanks for the info, I'll look out for that.
    Thanks for correcting me, I hate giving out false info!
  3. Posts : 72,075
       #152
    If they are standalone .exe files, then that would work just fine. However, if it's a .exe file for a installed 3rd party program, it most likely will not work. For example, Firefox.
    This is because when the program is installed, the registry entries for it all point to where the program was installed to (ex: C:\Program Files). If you run the actual .exe file from the desktop, then the other files it needs from the installed location (ex: C:\Program Files) cannot be found and thus the program does not run or gives a error. This is why a shortcut is used instead since a shortcut will run the .exe from it's installed location.
  4. Posts : 3
       #153
    Hmm. I feel like I really should have known that...
    Thanks, I'm gonna go work on a MSCE training now.
    Apparently, I need it.
  5. Posts : 72,075
       #154
    LOL, no problem mate. Thanks for trying to make an addition though. :)
  6. Posts : 80
    Windows 7 Professional x64 | Windows ME | Windows 8 Dev Preview
       #155
    Hi Brink. Is it possible to use a different overlay icon for symlinks? symlinks uses the same overlay arrow that shortcuts use. I would like to be able to tell which is which by marking symlinks with a different arrow and to avoid going into Properties.
  7. Posts : 72,075
       #156
    Hello AJ,
    I'm not sure how to change that one, but it would be a good question to ask/post in the Customization forum area. :)
  8. Posts : 80
       #157
    Brink,
    Thanks. I'll do that.
  9. Posts : 23
    Window 7 Home Premium x64
       #158
    Hi, I'm getting this error and if I used any third party application to remove the shortcut, the shortcut icon replace by other icon. See the image below. I also tried to rebulid the icon cache.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ComponentModel.Win32Exception: The system cannot find the file specified
    at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
    at VistaArrowGone.Form1.btApply_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
    FxVisor
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Program%20Files/Frameworkx/FxVisor/FxVisor.exe
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  10. Posts : 72,075
       #159
    Hello Anu,
    Rebuilding the icon cache will not help with this issue since it's a shortcut arrow overlay issue on the icon instead of the actual icon. You should be able to use OPTION ONE to either restore the default arrow overlay, or what you like.
