Shortcut Arrow - Change, Remove, or Restore
Page 17 of 35 FirstFirst ... 7151617181927 ... LastLast
  1. Posts : 23
    Window 7 Home Premium x64
       #160
    Fix it .
  2. Posts : 71,959
       #161
    That's great news Anu. I'm happy to hear that you got it fixed. :)
  3. Posts : 23
       #162
    I saw there was a file named WebpageIcons just deleted and reboot my system and win7 automatically generate a new icon file.
  4. Posts : 71,959
       #163
    How odd. Was it part of some skin or theme you installed?
    Where was this file located at?
  5. Posts : 23
       #164
    Nope not a part of any theme in my opinion. I just installed the fresh OS in my system that time. Same place of Iconcache C:\Users\anuo512\AppData\Local
  6. Posts : 71,959
       #165
    I don't have that file on my system, but I'm glad you got it sorted. Thank you for posting back. :)
  7. Posts : 23
       #166
    Even I don't have any idea where it comes from. I uploaded the file have a look if you like.
    Shortcut Arrow - Change, Remove, or Restore Attached Files
  8. Posts : 1
    For the second option, you don't need to restart. Right-clicking the desktop and selecting "Refresh" worked for me.
  9. Posts : 15
    Windows 7 Pro 64bit
       #168
    Okay I demand a help i used OPTION THREE. I downloaded the file and doesn't see any unblock at the properties so i skipped at Letter D. I restarted the computer and it shows the blank transparent icon just as what in the warning says! Need help on this. How to get rid of it
  10. Posts : 71,959
       #169
    Hello testrun, and welcome to Seven Forums.
    Did you unblock the Blank.ico file first before moving it into C:\Windows in step 2C? If not, then you will need to move the file in C:\Windows to your desktop, unblock it, and move it back to C:\Windows.
    If that doesn't help, then OPTION ONE is great for removing the shortcut arrow. :)
