#160
Fix it .
I saw there was a file named WebpageIcons just deleted and reboot my system and win7 automatically generate a new icon file.
Nope not a part of any theme in my opinion. I just installed the fresh OS in my system that time. Same place of Iconcache C:\Users\anuo512\AppData\Local
I don't have that file on my system, but I'm glad you got it sorted. Thank you for posting back. :)
Even I don't have any idea where it comes from. I uploaded the file have a look if you like.
For the second option, you don't need to restart. Right-clicking the desktop and selecting "Refresh" worked for me.
Okay I demand a help i used OPTION THREE. I downloaded the file and doesn't see any unblock at the properties so i skipped at Letter D. I restarted the computer and it shows the blank transparent icon just as what in the warning says! Need help on this. How to get rid of it
Hello testrun, and welcome to Seven Forums.
Did you unblock the Blank.ico file first before moving it into C:\Windows in step 2C? If not, then you will need to move the file in C:\Windows to your desktop, unblock it, and move it back to C:\Windows.
If that doesn't help, then OPTION ONE is great for removing the shortcut arrow. :)
