Shortcut Arrow - Change, Remove, or Restore
Page 27 of 35 FirstFirst ... 172526272829 ... LastLast
  1. Posts : 23
    Windows 7 Home Premium 32bit
       #260
    OK, perhaps this is because I didn't 'undo' Option 3 before. I've now done that, and removed Blank.ico. I've also uninstalled VSM, which perhaps I also should have done before, and have re-applied Option 2, which, after a reboot, seems to have worked. All that remains to be seen is whether it will 'stick' this time.
  2. Posts : 72,058
       #261
    I hope so. Please let us know how it goes.
  3. Posts : 23
       #262
    Brink said:
    I can understand that. Do you have a restore point dated before you had these issues available?
    VSM was one of the first things I installed, which was when I first installed the OS, so System Restore may not go back that far, but I did take a registry backup the other night, before I started fiddling with this. But that would have included whatever VSM did.
  4. Posts : 23
       #263
    Well, Option 2 has survived a second reboot, so hopefully, the fix will stick this time.
    Thanks again for your support. :)
  5. Posts : 72,058
       #264
    You're most welcome. Sounds good so far. :)
  6. Posts : 23
       #265
    That's what I thought this morning!
  7. Posts : 72,058
       #266
  8. Posts : 23
       #267
    After a whole day of being fine, I started my PC again this evening, and the black boxes have returned to the Desktop icons!! I really don't understand what could be happening, but I've observed two things:
    1. I observed last night that when I Rebuild_Icon_Cache (with the Reg thing), the icons revert to being as they should, without the arrows. Before I used Option 2, the arrows came back after an icon cache flush, so obviously something there is working right.
    2. This evening, I didn't flush the icon cache, but reverted to the 'normal' text size in Personalize > Display. After the forced log out / in cycle, the icons appeared as they should. I then reverted to my custom 110% display, and the icons stuck as they should (no black boxes). Something weird there?
    So, it does appear to be something to do with using a custom text size, even though the icons are the same size using the custom and default text sizes. Having said that, using the default (100%) text size produced a space, vertically, for one more icon in a column on my Desktop, but I assume that's because of the reduced text size, and possibly different icon spacing?
    What I've done now is, left the text size in Personalize > Display at the default 100%, and adjusted some of the font sizes in the advanced settings, so I'll see how that goes.
    One quick question, slightly off topic - how can I make the system tray display just the time, and not the time with the date underneath? Increasing the text size in Personalize > Display achieves this, but I can't find any adjustment for the system tray font anywhere else.
  9. Posts : 23
       #268
    Well, that hasn't worked either. It seems to hold until I completely shutdown the machine, then on restarting, the black boxes appear again.
  10. Posts : 72,058
       #269
    Simon,
    You might see if running a sfc /scannow command may be able to help if you have any corruption responsible for this.
