Shortcut Arrow - Change, Remove, or Restore
Page 32 of 35 FirstFirst ... 223031323334 ... LastLast
  1. Posts : 72,041
       #310
    Hello DeMatador, and welcome to Eight Forums.
    Unfortunately, the classis arrow is only up to 32x32 16 colors. When you use an extra large icon for the file, the arrow will have an outline like that.
    If you like, you could use the transparent arrow to avoid using the default arrow.
  2. Posts : 2
    That's too bad. Would it be possible, then, to use one of the other methods to replace the default arrow without outright removing all arrows? See, I'm kinda afraid I'll end up relying on shortcuts thinking they're the real deal, and, say, move them to a drive (I move my files a lot between drives) only to find out the file was a .lnk file in disguise. I know it sounds silly, but I don't wanna risk it, so I thought, maybe I can use a smaller arrow. Since apparently I can't, would it be possible to take the default arrow, edit it in Photoshop and take its opacity down to ~25% so that it's barely noticeable, and then make that new semi-transparent arrow the shortcut arrow?
    I did try to use Option One (through the "Custom Arrow" option) but the outline kept appearing, even though the image for the semi-transparent arrow is supposedly the same size as the default arrow... I'm thinking the .png to .ico converter I'm using might be compressing the resulting .ico file into a 32x32 file. What size and color depth would the new arrow need to be in order to avoid the outline?
    Sorry if the post is kinda unintelligible, it's way too early to be typing this, haha.
  3. Posts : 72,041
       #312
    DeMatador,
    I hear you about being early, but your post is fine. :)
    You might see how the "Light Arrow" in OPTION TWO may work for you. It's smaller, and shouldn't give the outline on extra large icon view.
  4. Posts : 313
    Vista/Win7/8/10/11 (x86/x64)
       #313
    I agree with Shawn on this with using the ''Light Arrow'' is a really good one.
    I've tried in the past to create my own icon too, I ended up using the one that I posted in this thread back on this Post
    After many different variations realized that the Light Arrow or the one I posted turned out to be the best looking of all. It's the icon itself is what I use now irregardless of which option chosen to install it, and I think either of these two icons is what you would also appreciate too.
  5. Posts : 18
    Hi Brink,
    Anak sent me here from this thread. My question is this: Is it possible to remove the shortcut arrow from Junction Points... but only the JPs and not all shortcuts? Any ideas would be much appreciated :)
  6. Posts : 72,041
       #315
    Hello Clonkex,
    I'm not aware of a way to do so for JPs.
  7. Posts : 18
    No problem, just thought I'd ask :)
  8. Posts : 18
    Anak just suggested a solution. Link Shell Extension does exactly what I need! I just created a 256x256 blank, transparent icon with Gimp and used that in LSEConfig
  9. Posts : 92
    Windows 7 Professional x64
       #318
    I'm having a small problem. I downloaded the 'No_Shortcut_Arrow.reg' file and ran it. Everything works great, no problem.
    Here's the problem, though:
    When I restart/start up my computer the shortcut icons look like this:
    The black square goes away (on all the icons) when I double-click on any of the shortcuts. (Meaning after I double-click on any shortcut it works as intended. But before that it's covered by that black square.)
  10. Posts : 72,041
       #319
    Hello Phrosen,
    Does refreshing (F5) the desktop clear them?
