Shortcut Arrow - Change, Remove, or Restore
Page 6 of 35 FirstFirst ... 4567816 ... LastLast
  1. Posts : 72,136
       #50
    Hello PRT, and welcome to Seven Forums.
    Oops, letters in the steps fixed.
    The amount of tabs may vary from system to system depending on how they are set, but it is fine as long as the download is Unblocked in the General tab if needed.
  2. PRT
    Great - thanks. :)
  3. Posts : 72,136
       #52
    You're welcome. :)
  4. Posts : 1
    windows 7
       #53
    When I tried to merge the remove shortcut I receive a new window saying to run or cancel. I am running Windows home premium. Thanks
  5. Posts : 72,136
       #54
    Hello Frank, and welcome to Seven Forums.
    Yes, this is normal to approve the merge at step 2F. :)
  6. Posts : 40
    Windows 7 Home Premium
       #55
    Remove Shortcut Icon Arrows
    It worked like a charm. Thank you!
  7. Posts : 72,136
       #56
    You're welcome ColMac. :)
  8. Posts : 8
    WINDOWS 7 HOME PREMIUM 32 BIT
       #57
    THANKS FOR THIS REGISTRY TWEAK
    it worked fine with my windows 7 home premium 32bit
    now my desktop looks good with out those annoying shortcut overlays
    thanks
    thank u sooooooooo much
  9. Posts : 72,136
       #58
    You're most welcome Batman, and welcome to Seven Forums. :)
  10. Posts : 22,814
    W 7 64-bit Ultimate
       #59
    Thanks Brink, I hate those .... arrows.
