Shortcut Arrow - Change, Remove, or Restore
Page 8 of 35 FirstFirst ... 67891018 ... LastLast
  1. Posts : 9
    Okay so I did exactly like in method one. Copying the blanc.ico to the windows folder and merged the 64-file. This was the result..
    Attached Thumbnails Attached Thumbnails Shortcut Arrow - Change, Remove, or Restore-pict.jpg
  2. Posts : 72,043
       #71
    Hello Sara,
    Did you unblock (steps 2B -2C) the blanc.ico file before copying it to the Windows folder? This must be done first, since you will not be able to unblock it from the Windows folder location.
  3. Posts : 9
    As I said, I did everything in the tutorial.. Anyway I dunno what happened but after relogging two times without changing anything it worked. :/
    Kinda strange but it really worked.
  4. Posts : 72,043
       #73
    Sara,
    Not sure what may have caused the delay, but I'm happy to hear that it worked for you. :)
  5. Posts : 3
    Windows 7 Professional
       #74
    Forgive me if I've overlooked this, but, will this fix effect ALL shortcuts, or only ones you choose? I only want to remove the icon from select shortcuts, not all of them.
  6. Posts : 72,043
       #75
    Hello Minalee,
    Unfortunately this will remove the shortcut arrow overlay icon from all shortcuts. There's not a way to only remove them from a few of them
  7. Posts : 5
    windows 7 ultimate 32 bit
       #76
    Thanks for the tutorials, but am wandering how can i change my shortcut arrow icon with the one Ive downloaded?
  8. Posts : 72,043
       #77
    Hello Glassjaw,
    You would just need to type in the full path of where the .ico file that you want to use is saved at in quotes at step 5 instead.
    For example:
    "C:\Users\user-name\Pictures\myiconfile.ico"
  9. Posts : 5
       #78
    yes ive done that, but when i reboot my comp. it doesnt change. ill better try again...
  10. Posts : 1
    Windws 7 32bit
       #79
    If you don't want to download any programs:
    Open the key [HKEY_CLASSES_ROOT\CLSID\{63B51F81-C868-11D0-999C-00C04FD655E1}\InProcServer32] and delete the current value of "(Default)". To restore set the value of "(Default)" back to "C:\\WINDOWS\\SYSTEM\\SHELL32.DLL" where WINDOWS is your Windows directory.
