Desktop Icons - Hide or Show
Page 6 of 7 FirstFirst ... 4567 LastLast
  1. Posts : 1,364
       #50
    Brink said:
    Hello Marc, :)
    That's normal when using the .bat files. They need to restart explorer to apply.
    oh well, it was a nice idea - thx Shawn
    p.s. if anyone comes up with a clean toggle for hide/show let me/us know -laters
  2. Posts : 1,364
       #51
    This is it : Desktop Icons - Hide or Show Toggle Key
  3. Posts : 721
    Windows 10, Windows 8.1 Pro, Windows 7 Professional, OS X El Capitan
       #52
    ​Because writing to the registry is not the proper way to toggle Show Desktop Icons, restarting Explorer is the only way for a batch file to get it to read newly assigned registry values. This unfortunately has the caveat of closing all Explorer windows.
    Utilising C# code, PowerShell may interact with the Windows API. This allows for a "clean" way of toggling that Show Desktop Icons using a builtin script.
    ToggleShowDesktopIcons.ps1
    $signatures = @'
    [DllImport("user32.dll")]
    public static extern IntPtr FindWindow(string lpClassName, string lpWindowName);
    public static extern IntPtr FindWindowEx(IntPtr hwndParent, IntPtr hwndChildAfter, string lpszClass, string lpszWindow);
    public static extern IntPtr SendMessage(IntPtr hWnd, uint Msg, IntPtr wParam, IntPtr lParam);
    $API = Add-Type -MemberDefinition $signatures -Name 'Win32' -Namespace 'Win32Functions' -PassThru
    $progman_handle = $API::FindWindow('Progman', 'Program Manager')
    $shellviewwin_handle = $API::FindWindowEx($progman_handle, 0, 'SHELLDLL_DefView', '')
    [void]$API::SendMessage($shellviewwin_handle, 0x0111, 0x7402, 0)
  4. Posts : 72,062
       #53
    Great job Pyprohly. :)
  5. Posts : 1,364
       #54
    I agree (tho I have no understanding of the posted code whatsoever ). Shawn, will this be incorporated into this tutorial, or how would I do it here at home?
  6. Posts : 72,062
       #55
    Yeah, I'll get it added later tonight. :)
  7. Posts : 1,364
       #56
  8. Posts : 72,062
       #57
    Marc,
    I've been playing with the .ps1 file, but I'm just not sure how it's any easier than just using OPTION ONE when you still need to right click on the .ps1 file and click on "Run with PowerShell".
    You could create a .bat file to run the .ps1 file with PowerShell.exe though.
  9. Posts : 1,364
       #58
    Brink said:
    Marc,
    I've been playing with the .ps1 file, but I'm just not sure how it's any easier than just using OPTION ONE ...
    Thx for the effort. I've no clue what all is happening/involved, thought maybe the code would be incorporated into your OPTION TWO, I do not like having all my open explorers closed.
    Option One and/or the app referenced in post#51 will suffice.
    -thx
  10. Posts : 721
       #59
    A good idea would be to shortcut it: assign the script a hotkey. I can't imagine why anyone would want to recreate the Show Desktop Icons functionality if their intentions aren't to bind it to a hotkey.
    If it helps, any PowerShell script can easily be turned into a batch file by placing the below lines at the top of the script and renaming the file accordingly (with a .bat extension). (Caveat: the resulting script will not be able to accept arguments. Though, there exists another version for that.)
    @powershell -Command Invoke-Expression $([String]::Join([char]10, (Get-Content \"%~f0\")))"
    @goto :eof
    E.g.
    ToggleShowDesktopIcons.ps1.bat
    @goto :eof
    $signatures = @'
    Brink, MourningStar, the PowerShell script I posted was just a demonstration of a native solution for toggling Show Desktop Icons in a clean way, to satisfy MourningStar. I posted the PowerShell script to prove that such native solution does exist. I didn't expect both of you to want to incorporate the script in the tutorial, so I kept the script short and simple, at the price of ignoring a noteworthy bug. But if you guys wish for an proper improvement to Option Two, that can be done...
    Especially with Windows 8 or newer, there is an issue with the 'ToggleShowDesktopIcons.ps1' script where it fails to toggle desktop icons on or off after the user changes their desktop wallpaper. The script works again after restarting Windows Explorer.
    TL;DR,
    This bug occurs because SHELLDLL_DefView (the window where the desktop icons are drawn, and the thing that gets destroyed and recreated when a desktop refresh takes place), the usual child window of the "Program Manager" shell, detaches from "Program Manager" to a new shell which has the class name of "WorkerW" and are a good number of windows that have the same class name, so locating SHELLDLL_DefView when this happens is no easy chore. I believe the reason why SHELLDLL_DefView is moved is to allow for the smooth transition effect. I'm not sure when SHELLDLL_DefView moves back to begin a child window of Program Manager, or if it does at all.
    The PowerShell script below is safe from the mentioned bug. It looks full on though. And all it's doing is executing C# code.
    ToggleShowDesktopIcons2.ps1
    $source = @'
    using System;
    using System.Runtime.InteropServices;
    namespace DesktopUtility
        class Win32Functions
            public static extern IntPtr GetDesktopWindow();
        public class Desktop
            public static IntPtr GetHandle()
                IntPtr hDesktopWin = Win32Functions.GetDesktopWindow();
                IntPtr hProgman = Win32Functions.FindWindow("Progman", "Program Manager");
                IntPtr hWorkerW = IntPtr.Zero;
                IntPtr hShellViewWin = Win32Functions.FindWindowEx(hProgman, IntPtr.Zero, "SHELLDLL_DefView", "");
                if (hShellViewWin == IntPtr.Zero)
                    do
                        hWorkerW = Win32Functions.FindWindowEx(hDesktopWin, hWorkerW, "WorkerW", "");
                        hShellViewWin = Win32Functions.FindWindowEx(hWorkerW, IntPtr.Zero, "SHELLDLL_DefView", "");
                    } while (hShellViewWin == IntPtr.Zero && hWorkerW != null);
                return hShellViewWin;
            public static void ToggleDesktopIcons()
                Win32Functions.SendMessage(Desktop.GetHandle(), 0x0111, (IntPtr)0x7402, (IntPtr)0);
    Add-Type -TypeDefinition $source
    [DesktopUtility.Desktop]::ToggleDesktopIcons()
    Combine this script with four special lines and you've got quite a power-shell batch file.
    Edit: I've attached a Batch-wrapped ToggleShowDesktopIcons2.ps1 PowerShell script to this post, and I have also included a binary version of it.
    Edit 2: Fixed execution policy error message in batch file.
    Desktop Icons - Hide or Show Attached Files
    Last edited by Pyprohly; 16 Jan 2016 at 11:27. Reason: Fixed execution policy error message in batch file.
