Gadgets - Enable or Disable
Page 1 of 4 123 ... LastLast
    How to Enable or Disable Gadgets in Windows 7 and Vista
    This will show you how to enable or disable all currently running gadgets, and from being able to add new desktop gadgets for specific or all users in Vista and Windows 7.
    You must be logged in as an administrator to be able to do the steps in this tutorial.
       Warning
    For you to be able to use and add gadgets to your desktop, you must:
    • Have gadgets enabled below.
    • Show Desktop Items needs to be checked in order to see the gadgets.
    EXAMPLE: "Desktop gadgets are managed by your system administrator."
    NOTE: When gadgets is disabled, this will be the message all users will get when they try to add a gadget.
    OPTION ONE
    Using a REG File Download
    1. To Enable Gadgets for Current User
    Enable_Gadgets.reg
    B) If not already, make sure that you have Windows Gadget Platform checked in Windows Features.
    C) Go to step 3.
    2. To Disable Gadgets for Only Current User
    Disable_Gadgets.reg
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. Log off and log on, or restart the computer to completely apply.
    NOTE: Gadgets that are currently running may not be disabled until you do this step.
    7. When done, you can delete the downloaded .reg files on the desktop if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, Windows Components, and Desktop Gadgets. (See screenshot below)
    3. In the right pane, right click on Turn off desktop gadgets and click on Edit. (See screenshot above)
    4. To Enable Gadgets
    A) Select (dot) either Not Configured or Disabled. (See screenshot below step 6)
    C) Go to step 6.
    5. To Disable Gadgets
    A) Select (dot) Enabled. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
    8. Log off and log on, or restart the computer to completely apply.
  1. Posts : 35
    windows 7 ultimate 32bit
    thanx
    hi and thanx for every thing this worked good
  2. Posts : 72,049
    You're most welcome Anas Malas, and welcome to Seven Forums. :)
  3. Posts : 2,737
    Note: The registry change only seems to work in Vista. I could not get it to work in Windows 7.
    Here is how to do it in Windows 7 :
    Gadgets - Turn On or Off
  4. Posts : 72,049
    Hello WindowsStar,
    It still works fine for me. Did you log off and on, or restart the computer afterwards?
  5. Posts : 2,737
    Brink said:
    Hello WindowsStar,
    Yes I sure did (log off and back on as well as reboot).
    The above Registry Modifications do not work in Windows 7, or at lest for me, I tried several machines. Howerver the replaced link pointing to uninstalling Gadgets does work perfectly in Windows 7.
    Thanks for fixing my link. -WS
  6. Posts : 72,049
    Hmmm, ok. Let's see if we can figure out why it's not working for you.
    Is there any particular part that is or is not working? For example:
    • Do you get the example message when you right click on the desktop and click on Gadgets after disabling gadgets?
    • Is is that the currently loaded gadgets to not get turned off after log off or restart when set to disabled? If so, what gadgets?
    • Does using the Group Policy option instead work for you?
  7. Posts : 2,737
    Humm; Picture worth a thousand words:
    Forgot to say I did not try the Local Policy.
    However the uninstall method works perfectly. -WS
    Attached Thumbnails Attached Thumbnails Gadgets - Enable or Disable-regpix.png   Gadgets - Enable or Disable-desktoppix.png   Gadgets - Enable or Disable-gadgetspix.png
  8. Posts : 72,049
    Double check at the registry location below to see if you may have a TurnOffSidebar DWORD entry. If you do, delete it.
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Windows\Sidebar
    You might also use the Find and Find Next option in regedit to search for any TurnOffSidebar DWORD entries other than at the location below, and delete any found.
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Windows\Sidebar
  9. Posts : 72,049
    Yeah, either method will basically do the same thing. It just bugs me that the REG files here will not work for you. Hopefully we'll find out why. :)
