Elevated Command Prompt Shortcut
  1. Posts : 20
    Brink said:
    Hello Magikill,
    Not a silly question at all. This may work for you.
    Add or Remove "Open Command Window Here as Administrator" to the Context Menu
    Oh my god this is awesome I don't think I did it right before lol .. you are by far the best person I know online m8 thank you so much
  2. Posts : 72,050
       #21
    You're most welcome Magikill. Thank you for the kind words. :)
  3. Posts : 98
    windows 7 home premium
       #22
    I downloaded the short cut and followed all of your instructions but the command prompt still opens with "C:\Windows\System32". I followed you instructions and went into the short cuts tab "advance" but my run as administrator was already checked. Any suggestions
  4. Posts : 72,050
       #23
    Hello Lartomar,
    I'm not sure what you mean. That's what it's suppose to open to in a elevated command prompt. See the example screenshot at the top of the tutorial.
    If your's is different, then please post a screenshot of it. :)
  5. Posts : 98
       #24
    I thought this was the tutorial I needed, maybe it is not.. I would like for the command prompt to open with "C:\Users\(user name). I am trying to ping a set top box(Boxee Box) that is on my network.
  6. Posts : 72,050
       #25
    Ah, ok. You can use the same shortcut, but just uncheck the Run as administrator box instead for to have it open unelevated to that location. :)
    You should also have one in your Start Menu by default at All Programs -> Accessories.
  7. Posts : 98
       #26
  8. Posts : 72,050
       #27
    You're most welcome. :)
  9. Posts : 1
    Windows 7 Professional 64
       #28
    I took a different approach to this. I created a batch file with the runas command and placed a shortcut named "su" pointing to the batch file in c:\windows so I can now press win + r and type su to get to my admin prompt. It still requires a password so it is totally secure and I set the path to my commands folder that I keep my batch files in so that I can use "su" in the command prompt.
  10. Posts : 2
    Windows 7 Home Premium 32bit.
       #29
    Thanks for that tip. It was very useful.
    Marc
