How to Create a "Scanners and Cameras" Shortcut in Windows 7 and Windows 8
This tutorial will show you how to create or download a Scanners and Cameras shortcut to use the Scanner and Camera Installation Wizard in Windows 7 and Windows 8.
The Scanner and Camera Installation Wizard is primarily designed to install drivers for older scanners and cameras—and some networked scanners—that aren't automatically recognized by Windows.
Before using the wizard, connect your scanner or camera and turn it on. If Windows recognizes the device and installs the appropriate driver, you're all set. There's no need to run the wizard.
EXAMPLE: Scanners and Cameras
NOTE: This is what this shortcut will open. Listed devices will depend on what you may have installed or connected of course.
OPTION ONE
To Download a "Scanners and Cameras" Shortcut
1. Click/tap on the Download button below to download the file below.
Scanners_and_Cameras.zip
2. Save the .zip file to your desktop.
3. Open the .zip file and extract the Scanners and Cameras shortcut to the desktop
4. Right click on the
Scanners and Cameras shortcut, and click/tap on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. In
Windows 7, you can now
Pin to Taskbar or
Pin to Start Menu, add to
Quick Launch,
assign a keyboard shortcut to it, or move this shortcut to where you like for easy use.
6. In
Windows 8, you can
Pin to Taskbar on desktop,
Pin to Start screen, add to
Quick Launch,
7. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
To Manually Create a "Scanners and Cameras" Shortcut
1. Right click or press and hold on an empty area of your desktop, and click/tap on
New and
Shortcut. (See screenshot below)
2. Type the location below into the location area, and click/tap on the
Next button. (See screenshot below)
%ProgramFiles%\Windows Photo Viewer\ImagingDevices.exe
3. Type
Scanners and Cameras for the name, and click/tap on the
Finish button. (See screenshot below)
5. In
Pin to Taskbar or
Quick Launch,
6. In
Windows 8, you can
Quick Launch,
