To have thumbnails instead of icons, you must also use a folder view other than Small Icons, List, ar Details. Thumbnails will display when the icon is small like that in those folder views in all Windows Explorer and Library folders.
You should be able to change these folder view sizes for the icons as well from the Start Menu location.
