Remote Desktop Connection (RDC) - Network
Page 14 of 18 FirstFirst ... 41213141516 ... LastLast
  1. Posts : 102
    Wind 7 Pro 64-bit
       #130
    Did not work for me
    Hi Guys,
    Been tryign off and on for months....
    I have 2 PC's in the same house with Win 7 Professional. NO Passwords - so that should make it easier... but it always asks for a user name and password.....
    What ...the... are these??? Let say Old-PC and New-PC. So I want to connect New-PC to Old-PC and use one of the programmes on it....
    No I do not want passwords as it makes life too hard well much harder than it shoudl be... I have wasted days on this simple thing.... Can anyone help?? Can ANYONE email me the instructions with screen shots??
    Dan
    Rural Australla - yes no one knows outwest.
  2. Posts : 13,354
    Windows 7 Professional x64
       #131
    Hello,
    Passwords are necessary in order to establish a RDC connection. Set a password on the host machine, make sure RDC is enabled, and make sure no firewalls are blocking the connection.
  3. Posts : 102
    Wind 7 Pro 64-bit
       #132
    Mate
    Thanks for the reply. Now I am a little slow... but which is the Host Machine?
    Dan
  4. Posts : 72,055
       #133
    Hello Dan,
    The host computer in a RDC would be the remote computer.
    Remote Desktop Connection: frequently asked questions
    Hope this help, :)
  5. Posts : 102
    Wind 7 Pro 64-bit
       #134
    Thansk Mate
    But how do I, and where do I put the password for the host (Old-PC)??
    Since it is in my house can I avoid a password - I hve too many
    Dan
  6. Posts : 72,055
       #135
    Dan,
    Sorry, but no. RDC requires the use of passwords.
    When you get to OPTION ONE in the tutorial, you will type in the password of the host computer's user account that you logging into via RDC at step 5. :)
  7. Posts : 102
    Wind 7 Pro 64-bit
       #136
    Mate
    Sorry I am confused.
    I have read the tut and it makes limited sense.
    Do I do this on the PC I want to connect to (Old-PC) and do I do this while sitting at the Old-PC
    Also it says enter the remote PC, but do not I want to se the Password on Old-PC (i.e. the one I am at)??
    What is my user name? As I have mentioned, I do not use passwords on any of my home PC's - sorry for being stupid.
    Dan
  8. Posts : 72,055
       #137
    The Old-PC that you want to connect to via RDC must have a password for it's administrator user account.
    The "First" and/or "OPTION TWO" sections in the tutorial must be done on the (Old-PC).
    The "OPTION ONE" section needs to be done on the (New-PC).
    While sitting at (New-PC) to connect via RDC to (Old-PC) doing "OPTION ONE", you would type in the computer-name, user-name, and password for the user account on (Old-PC).
  9. Posts : 102
    Wind 7 Pro 64-bit
       #138
    Mate - it is not working
    Option 1 at OLD-PC
    Asks for
    Remote PC = New-PC
    Unser Name = what is this? I do not have one.
    Then it says connect. But I am on Old-PC?? Should I not be on New-PC?
    Dan
  10. Posts : 72,055
       #139
    Yes, you should be on New-PC.
    Do "First" on Old-PC
    Do "OPTION ONE" on New-PC
    User name = name of your account on Old-PC
