Remote Desktop Connection (RDC) - Network
Page 17 of 18 FirstFirst ... 715161718 LastLast
  1. Posts : 8
    windows 7 ultmate x64
       #160
    i done this sittings but my problem is not solve i cant uderstand y its says incorrect user name or password
  2. Posts : 72,058
       #161
    You never directly answered the question below to help clarify if this was done as well.
    Are you using an user name and password of an account created on the remote PC to log in with?
  3. Posts : 8
       #162
    see this pic
    Attached Thumbnails Attached Thumbnails Remote Desktop Connection (RDC) - Network-5.png
  4. Posts : 8
       #163
    yes
  5. Posts : 72,058
       #164
    Double check through the posts at the link below to see if any may apply to you as well.
    Solved Remote Desktop, Username or Password incorrect
  6. Posts : 8
       #165
    problem not solve hey im connect to remote pc by xp mode and its connect then y it is not connecting in win 7 to win 7
    i
  7. Posts : 72,058
       #166
    I'm afraid that I'm at a loss as well for why.
  8. Posts : 8
       #167
    its ok
  9. PCG
    Windows 8.1 Pro with Media Center
       #168
    I have one desktop and two laptops with Windows 8 Pro, and one work laptop with Windows 7 Pro.
    I have successfully set up Remote Desktop Connections on and between all of these computers while inside my home and connected to my home network.
    I have tried unsuccessfully using a neighbors wireless signal to RDC in from the internet to no avail.
    I followed the instructions in this tutorial to enable RDC, including,
    1. Port forwarding has been set up on my router to my desktop
    2. Remote Desktop is allowed through the Windows Firewall (I'm not using third-party A/V).
    3. And, the forwarded port is enabled in Incoming Rules section of the Advanced Settings
    What am I missing here?
    Attached Thumbnails Attached Thumbnails Remote Desktop Connection (RDC) - Network-remote.png
  10. PCG
       #169
    24 hours and no replies...
    After reading more in to this, I came across several (mostly positive) references to the Free version of TeamViewer and decided to give it a try instead of Windows RDC.
    I have it loaded on all three laptops and my desktop, and it seems to be a fantastic app. It even has a small Windows 8 shortcut tab that's pretty cool.
    I have some international business trips coming up soon, and will test it out from a few different countries.
    I would still like to give RDC a try if some one here could point me in the right direction.
    Thank you
