#30
When you say that your router is forwarding port 3389 to the machine, you mean the IP of the Win7 PC, right? You did set the Win7 PC to accept RDC automatically, right?Oh hey there, how you doin? I've just registered and hope you guys might be able to help me...
I have Windows7 on this machine and all I am trying to do is set up Remote Desktop to connect to this PC from work.
I am behind a router, my PC is on 192.168.1.3 and have forward the default Remote Desktop port (3389) to that IP.
Now, when I use my WinXP laptop (same network) to test it, I only seem to be able to connect to my Win7 machine sucessfully by using a local ip (192.168.1.3) but if I type the IP address for my router there I just get: "Remote Desktop Disconected-> This computer cant connect to the remote computer..."
I have gone on a website which scans for open ports and 3389 is opened, the router is pointing that port to this machine and yet I cant seem to connect for some reason, have tried switching the firewall off on both machines and same issue.
I do have a proper user/password so its not because of a blank password either.
So I am very confused, the Desktop Connection works from within the LAN, which means there isnt any settings that need modifying on the Win7 machine, the router is forwarding the 3389 port to the machine and I have confirmed the port is opened, have tried disabling firewall on router, setting my machine (.3) as a DMZ server, even adding the :3389 after the IP address from the WinXP laptop and still... no joy....
Any ideas?
