Windows 7: Homegroup - Add or Remove from Navigation Pane
08 Jan 2018   #20
Brink
64-bit Windows 10 Pro
Hello BuckSkin,
No worries. Removing "Homegroup" from the navigation pane is only cosmetic, and will not affect any network abilities.
08 Jan 2018   #21
BuckSkin
Windows 7 Pro x64
Quote   Quote: Originally Posted by Brink View Post
Hello BuckSkin,
Thanks ! I appreciate your patience in answering my many questions.
And, If I go the route described in the link below, and completely eliminate Homegroup from all of our machines, will our home network still function ?
Remove HomeGroup from Windows Explorer in Windows 7 - TechRepublic
I have had all four machines entered in our Homegroup for quite some time; and, regardless of which machine I am using, only two of them ever show up either in the navigation menu or in the right pane when I click on Homegroup; the regular Network suits my purposes better and also allows me access to things that never appear under Homegroup.
Thanks for reading.
08 Jan 2018   #22
Brink
Doing what they posted at that link will completely disable Homegroup causing it to no longer work or be available.
08 Jan 2018   #23
BuckSkin
Windows 7 Pro x64
With Homegroup gone, will the normal Network still work ?
Thanks.
08 Jan 2018   #24
Brink
Yes, using workgroup will still work.
Favorites - Add or Remove from Navigation Pane
How to Add or Remove Favorites from Navigation Pane in Windows 7 This tutorial will show you how to add or remove the Favorites folder in the Windows Explorer Navigation Pane in Windows 7. The default folder for Favorites is the Links folder located at the location below. ...
Tutorials
Recycle Bin - Add or Remove from Navigation Pane
How to Add or Remove Recycle Bin from Navigation Pane in Windows 7 The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full. This...
Tutorials
How can i remove items from navigation pane?
Hi. How can i remove shuttercut .? http://img829.imageshack.us/img829/8397/39149391.gif i want like this :) http://img844.imageshack.us/img844/7075/47133051.gif
Customization
Homegroup - Rename in Windows 7 Navigation Pane
How to Rename "Homegroup" in Navigation Pane in Windows 7 and Windows 8 This tutorial will show you how to rename the Homegroup folder in the Navigation Pane to any name that you like for all users in Windows 7 and Windows 8. You must be logged in as an administrator to be able to do the...
Tutorials
Remove things in Navigation pane
Ok so I know it is possible to remove things from the libraries pane in explorer which I have done, but this question is not about the explorer libraries pane but it is about the open file/folder/whatever libraries pane. How do you get rid of "Favorites", "Homegroup", and "Network"? If you only use...
Customization
