Homegroup - Add or Remove from Navigation Pane
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 72,052
    Yep, this one is not working properly on Windows 8 yet.
  2. Posts : 22,814
    W 7 64-bit Ultimate
    Thanks mate, I guess I'll go set the values back to default just to be on the safe side.
  3. Posts : 49
    I'm in Windows 8 too (Pro, x86 due to upgrading an older OEM PC), and I pulled up Services and disabled the two HomeGroup services. After a restart HomeGroup has not reappeared in my windows explorer left navigation pane.
  4. Posts : 72,052
    Hello lilsting,
    That will do fine as long as you do not want to create or join a Homegroup. :)
  5. Posts : 50
    Tomatoe
       #14
    Any chance of automating this? How do you change perms in batched in the registrY?
  6. Posts : 72,052
       #15
    Hello Conditioned,
    I'll add it to the list to look into, and post back if I'm able to get it to work properly. :)
  7. Posts : 1,009
    Windows 7 Ultimate 64 bit SP1
       #16
    I'd like to add an alternative way of removing homegroup :)
  8. Posts : 4
    Perfect! didn't even have to restart!
    cheers!
  9. Posts : 4
    Windows 7 Home Premium 64bit / Windows 10 Pro 64bit
       #18
    The way provided on here is pretty simple, but yeah no doubt that way is for sure much easier and quicker and you are disabling the services too, but I am not sure if the method provided on here would have done that also.
    Either way thanks to all!
  10. Posts : 514
    Windows 7 Pro x64
       #19
    I have all of our machines in a Homegroup, but I never use the Homegroup in the navigation pane to access any of them; I always just use the Network.
    That being said, if I remove Homegroup from the navigation pane, will it disable the Homegroup; and, if so, will it affect my Network abilities ?
    Thanks for reading.
