Taskbar - Pin or Unpin a Program
Page 5 of 11 FirstFirst ... 34567 ... LastLast
  1. Posts : 6
    7 beta
       #40
    yes. this is what i meant! thank you very much for your help, I will let you know how it goes when I try it after I get home.
  2. Posts : 71,977
       #41
    You're welcome Daniel. Hope it goes well.
  3. Posts : 6
    7 beta
       #42
    i figured it out. both boxes in the properties menu have to be checked for the taskbar to allow you to pin something to windows explorer. this doesn't really make sense to me. just because something is pinned somewhere doesn't mean it is a recent item. pinning abilities should be independent of frequency of use or recentness.
    thanks again for your help.
  4. Posts : 71,977
       #43
    Daniel,
    I'm happy to hear that you got it sorted out now. Yeah, you would think the they would make that separate.
  5. Posts : 3
    windows seven
       #44
    i´m sorry but when i tried to pin a shortcut from the desktop, this is what happens:
    theres a red icon instead of the blue arrow
    Please help!
  6. Posts : 71,977
       #45
    Hello Xzrd, and welcome to Seven Forums,
    Do you have Recent Programs and Recent Items turned on?
  7. Posts : 2,899
       #46
    hey brink just wanted to let you know that they might be a workaround for folders and have no idea how i made i get here but i got
    oh and its unstable meaning that it will disapear and will go to the windows explorer shortcut and click and it will regain focus...
    oh and it behaves like wmp x64 meaning that the name would not be shown correctly...
  8. Posts : 71,977
       #47
    Hi DA,
    That does look interesting. To bad it is not stable though. I'll have to look into one. :)
    Thank you,
  9. Posts : 25
    Windows 7 Home Basic
       #48
    I know it is possible to drag a file that has a program associated for it (ex: .txt file for Notepad) to an empty area on the taskbar, so as to pin it.
    However is it possible to pin the file itself, so one doesn't have to right click on the program icon, then move the mouse up and left click on the file you want opened. It was possible to open a file pinned to the quickstart area in Windows XP with one step, and now it seems to be three steps - my only complaint with Windows 7 so far. But I might just be missing a simple solution..
    Thanks in advance for any help.
  10. Posts : 71,977
       #49
    Hello Fritz, and welcome to Seven Forums. :)
    Sorry but no, you cannot pin a document for a program like that separately onto the taskbar in Windows 7.
    However, you can use the same method for adding Quick Launch to the taskbar to add a folder with your documents instead on the right side of the taskbar.
