Aero - Enable Slow Motion Effect
    How to Enable Slow Motion Effect with Aero in Windows 7
    How to Enable Slow Motion Aero Effect in Windows 7
    In Windows 7 and Windows Vista, the Aero effect has a small delay of some milliseconds when minimizing, maximizing , closing and flipping Windows. This will show you how to manually force a delay on this effect to view it in slow motion.
       Warning
    You must be logged on as an Administrator to perform this tutorial.
    Option One
    Through a download
    1. To Enable Slow Motion Aero Effect with Shift Key -
    A) Download this file below:
    B) Go to step 3.
    2. To Undo Slow Motion Aero Effect with Shift Key -
    3. Open the .reg file you just downloaded. When prompted whether to import the data to the registry or not, select "YES".
    4. Log off and log back on.
    5. If enabled, while holding down the Shift key, minimize, open, close, or restore any window. Notice the effect. Video is included at the bottom of the post. You can also use Windows Flip 3D by pressing CTRL+WinKey+Tab, then holding down the Shift key, click to maximize the windows.
    Option Two
    The Manual Way
    1. Open regedit and navigate to
    HKEY_CURRENT_USER\Software\Microsoft\Windows\DWM.
    2. To Enable Slow Motion Aero Effect with Shift Key -
    A) In the right pane, right click on a empty space and click on New and Dword (32-bit) Value.
    B) Rename the new value to AnimationsShiftKey.
    C) Double click the AnimationShiftKey and type 1 in place of 0.
    A) In the right pane, right click on AnimationsShiftKey and click on Delete.
    B) Click on Yes to approve deletion.
    3. Close regedit, log off and back on.
    4. If enabled, while holding down the Shift key, minimize, open, close, or restore any window. Notice the effect. Video is included at the bottom of the post. You can also use Windows Flip 3D by pressing CTRL+WinKey+Tab, then holding down the Shift key, click to maximize the windows.
    That's it.
    Limneos
  1. Posts : 995
    XP/win7 x86 build 7127
    i guess its not possible to have windows animate in other ways, like transisitonal effects when closed or opened or when a webpage changes... more along the lines that a tablet or touchscreen would see/uses when in use
  2. Posts : 4,925
    Windows 7 Professional 64-bit
    You might want to include a registry undo .reg file with the tutorial in case people dont like it.
  3. Posts : 72,063
    Hello Swarfega.
    Good idea. It has been added. :)
  4. Posts : 154
    Windows 7 Build 7100
    I still don't know why anyone would want the computer to go slower.. But good find.
  5. Posts : 18,404
    You and me both...
    I could see where it could become severely annoying.
  6. Posts : 1,009
    Windows 7 RC 7100 32bit/64bit
    This doesn't make the default behaviour to go slower,
    it enables the forced slow motion while pressing the shift key. If you don't press the shift key, the windows animate normally.
    You don't "make the computer to go slower", you just view the effect in slow motion.
    So you dont' even need to undo it with a reg file I guess, you just don't press the shift key.
  7. Posts : 2
    Windows 7 Ultimate built 7100
    By this method windows maximize normaly.. No changes detected :-w
  8. Posts : 8
    Windows 7 RTM x64
    blacksmoke: Same to me.
    How can I get the toolbar which is in this vid on the top of screen in Win 7? THX Prochy
  9. Posts : 72,063
    Hello Prochy,
    That would be the free RocketDock. :)
