#30
@Brink
I've reported the "bug" to MS but they simply ignored it and didn't even fully understand the problem.
If you can, as MVP, please report this problem.
The OS should display the selected application as the icon for the "Open" button (as a matter of fact the registry uses 'DefaultIcon=%1'), not fall back to a generic file icon...
For sure they have more important things to fix in the OS, but if they fix too would be better :)
What MS really needs is a direct contact with the users... That's what makes great and constantly evolving for example Linux. You can contact the author and report a bug and it will be fixed for sure. When will MS fully understand this?
