Open Application Toolbar and Context Menu Icon - Fix
Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. Posts : 1
    Windows 7 Home Premium 64-bit SP1
       #40
    Thanks a lot for this!
  2. Posts : 53
       #41
    ....mmmh, and what about removing only the generic (ugly) icon near the Open button instead of replacing it in explorer bar + pop-up menus?
    Since it's just the Open command it makes sense, as option, not to use any icon for exes...
  3. Posts : 72,046
       #42
    You're most welcome SnowOak, and welcome to Seven Forums. :)
    Hello Hexaae,
    You could substitute the Application_Icon.ico file from the download in step 1 with a transparent blank icon of your own to use instead to not have a icon display since it would be transparent. :)
  4. Posts : 3,302
       #43
    Does anyone know if the open in the context menu should display an icon for other files to.
    For example if I right click a pdf file I get the adobe icon on the toolbar but not in the context menu.
    Is this correct.
    Thanks Danny
  5. Posts : 53
       #44
    It's correct.
  6. Posts : 1
    Windows 7 64 bit
       #45
    Hey, I want to thank you for your contribution here. You don't know how annoyed I am with that missing icon.
    I do have a couple of questions for you.
    First... is the missing icon a problem with just a rare few of us or all of windows 7 users?
    Second, can you tell me exactly how to uninstall this fix completely and revert windows back to right where it was... just because I'm terribly OCD about these things.
  7. Posts : 72,046
       #46
    Hello Respen, and welcome to Seven Forums.
    Yes, the missing icon is a minor graphical bug that affects all Windows 7 installations for everyone.
    To reverse the fix, you would just need to delete the Application_Icon.ico file in the C:\Windows\System32 folder. Next, delete the Icon key in the left pane of the registry at the location in step 8.
  8. Posts : 1
    Thanks a lot!
    Long for it! Appreciate it so much!
  9. Posts : 72,046
       #48
    You're most welcome Adam, and welcome to Seven Forums. :)
  10. Posts : 26
    Windows 7 Home Premium Service Pack 1 x64
       #49
    Is this fix compatible for x64? I think so, but due to some reasons its not working for my x64bit edition. I remember that when I used x32bit version, this fix worked perfectly.
    Take Care
