Games Explorer Folder - Restore Default Games
    How to Restore the Default Games in Windows 7 Games Explorer Folder
    This will show you how to restore the default Windows 7 More Games, Chess Titans, FreeCell, Hearts, Internet Backgammon, Internet Checkers, Internet Spades, Mahjong Titans, Minesweep, Purple Place, Solitaire, and Spider Solitaire games in the Games folder.
    The Chess Titans, Internet Backgammon, Internet Checkers, Internet Spades, Mahjong Titans games are not available in the Windows 7 Starter and Home Basic editions.
    The Games folder is central repository for games on your computer that also offers game updates, statistics, news feeds, WEI requirements, and more. For more information about the Games Explorer folder, see: Explore the features: Games Explorer
       Tip
    You will need to have the game unhidden, or default game checked in Windows Features, before it will be displayed in the Games folder. By default, Games is checked and turned on in all editions except the Professional and Enterprise editions.. You can also uncheck one of the default games to remove it from the Games explorer folder. This does not apply to installed 3rd party games.
    EXAMPLE: Games explorer folder
    NOTE: You can open the Games folder by clicking on the Games button on the dark right side of the Start Menu, typing shell:games in the Start Menu search box and pressing enter, or navigating to the hidden C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games folder.
    Here's How:
    1. To Restore All Default Games in the Games Explorer Folder
    Restore_All_Default_Games.zip
    B) Click on Save, and save the ZIP file to your desktop, then extract the .reg file from the ZIP file.
    C) Go to step 15.
    2. To Restore "More Games" to the Games Explorer Folder
    More_Games.reg
    B) Go to step 14.
    3. To Restore "Chess Titans" to the Games Explorer Folder
    Chess_Titans.reg
    B) Go to step 14.
    4. To Restore "FreeCell" to the Games Explorer Folder
    FreeCell.reg
    B) Go to step 14.
    5. To Restore "Hearts" to the Games Explorer Folder
    Hearts.reg
    B) Go to step 14.
    6. To Restore "Internet Backgammon" to the Games Explorer Folder
    Internet_Backgammon.reg
    B) Go to step 14.
    7. To Restore "Internet Checkers" to the Games Explorer Folder
    Internet_Checkers.reg
    B) Go to step 14.
    8. To Restore "Internet Spades" to the Games Explorer Folder
    Internet_Spades.reg
    B) Go to step 14.
    9. To Restore "Mahjong Titans" to the Games Explorer Folder
    Mahjong_Titans.reg
    B) Go to step 14.
    10. To Restore "Minesweeper" to the Games Explorer Folder
    Minesweeper.reg
    B) Go to step 14.
    11. To Restore "Purple Place" to the Games Explorer Folder
    Purple_Place.reg
    B) Go to step 14.
    12. To Restore "Solitaire" to the Games Explorer Folder
    Solitaire.reg
    B) Go to step 14.
    13. To Restore "Spider Solitaire" to the Games Explorer Folder
    Spider_Solitaire.reg
    14. Click on Save, and save the .reg file to the desktop.
    15. Right click on the downloaded .reg file and click on Merge.
    16. Click on Run, Yes, Yes, and OK when prompted.
    17. Close and reopen the Games explorer folder to apply and see the default game restored.
    18. When done, you can delete the downloaded .reg file if you like.
  1. Posts : 2,036
    Windows 7 Professional x64
    I think some people who get Windows 7 Professional will be "confused"
    Games are not enabled by default in Pro. You have to go to "Programs and Features" then "Turn Windows features on or off" and enable games from there in Professional.
    For anyone's information who may be searching for information about why their computer has no games listed.
  2. Posts : 72,046
    Thank you Nate. I added this in the TIP section. :)
  3. Posts : 11
    xp
    nate42nd is correct, that is best solution to enable all default games
  4. Posts : 2
    Windows 7 Pro
    Windows 7 Pro Games Disappeared
    I reset the Games Active on the Control Panel per the posting and the games still sre not coming back. I do not know what to do next. Can someone help?
  5. Posts : 72,046
    Hello Karen, and welcome to Seven Forums.
    Did you already make sure that the games were turned on in Windows Features from the yellow TIP box at the top of the tutorial first? If they were, then try toggling them off and on to see if that may help.
  6. Posts : 2
    Windows 7 Pro
    Yes, I followed those instructions and the only games that show up are Chess Titams and Mahjong Titans, even though all are checked! Very frustrating!
  7. Posts : 72,046
    Karen,
    If this happened not to long ago, then you may be able to do a system restore using a restore point dated when they were there to see if it can restore them for you.
  8. Posts : 2
    Windows 7 Home Premium, 32 bit
    ok, so i've run your download to restore the games etc, have toggled the features switch & restarted the system then rechecked all of the games in features and it still wont work. I've gone in an re-set the permissions so that i have full control and show as the Owner but.....the only game that loads up is Chess Titans. Any further ideas?
  9. Posts : 72,046
    Hellp Mike, and welcome to Seven Forums.
    As above, if this just happened not to long ago, then you may be able to do a system restore using a restore point dated when they were there to see if it can restore them for you.
