Taskbar - Customize Skin
  1. Posts : 72,062
    Generator said:
    Regarding step 2,
    for those struggling to find the resource's, the images for build 7229 are as follows:
    This maybe the same for other builds.
    Thank you Generator. I have updated the tutorial to include these. :)
  2. Posts : 575
    7600 x86
    thanks for the update Generator!
  3. Posts : 6
    Hi, just an update with my findings in windows 7 RTM. For the taskbar the images is the same as in 7229.
    I also made a pic to display what numbers the pictures have for a window.
    Finally you can use Universal Theme Patcher to patch windows 7
    TCP-Z, Best TCP/IP Patch: Universal Theme Patcher (v1.5, Build 20090409)
  4. Posts : 1
    windows 7, ubuntu,
    i downloaded ux theme patch,, and when i open the dll file in resource tuner,, i cant find ne images? that match what you described,, ne help ?? plz
  5. Posts : 6
    aero.msstyles is not a dll file. Please read the first post in this thread.
  6. Posts : 16
    Windows 7 SP1 32bit
       #15
    Can someone attach files for blue start menu, windows 7 final?
  7. Posts : 1
    windows 7 x 32
       #16
    really really really new to this where do i find the files that i have to patch for the uxtheme patch ?
  8. Posts : 6
    You will get all the files and instructions you need in the zip file that contains the theme you have downloaded from deviantart.com.
    Here is one black that I use:
    Ultimate for Windows 7 Basic by ~MediaMyself on deviantART
    But there is many, try to search for "windows 7 basic" on deviantart.
  9. Posts : 1
    windows 7 64 bit ultimate
       #18
    Windows 7 Basic Black Magic
    Hi
    I just made a black magic for the taskbar, when you are in basic mode.
    And thx for the great advice here to do it.
    Attached Thumbnails Attached Thumbnails Taskbar - Customize Skin-black-basic1.jpg   Taskbar - Customize Skin-black-madic2.jpg
    Taskbar - Customize Skin Attached Files
  10. Posts : 1
    Windows 7 Ultimate
       #19
    Just upgraded to Windows 7 Ultimate (32 bit) today - but I'm confused... when I go into the Aero folder I have to go farther, into the en-US folder... and then I find aero.msstyles.mui ... and I don't know what an MUI file is. Tried replacing it, to no avail. Is this something that is occuring on newer releases of Windows 7? Or am I just too computer illiterate to know what's going on? :)
