Disk Check
Page 11 of 14 FirstFirst ... 910111213 ... LastLast
  1. Posts : 72,043
       #100
    Cozzu,
    Did it mention the name of the recent program you installed?
    If not, then see if you may be able to boot to a command prompt at startup (boot) using OPTION TWO in the tutorial, to run chkdsk on the drive from there instead.
    Note that the drive letters are not always the same at boot as they are while in Windows.
  2. Posts : 44
    Hi.
    I want to tell Windows to check my data partition and to try to recover info from it (I mean, using /f /r switches) the next time the system boots. For it's not "in use" (if I click on "scan now" in the drive properties it will work, but all my program's instances will go down), I can't do it via the GUI. So I'd like to know what command you use to schedule a full scan of a partition the next time Windows boots (e.g. chkdsk /f /r D: )
    I learnt how to mark a drive as "dirty" and schedule it to be checked at boot time here (using METHOD THREE), but I wonder what kind of check it will do. Will it be a regular (/f) check or will it be a full scan, recovering data from bad sectors (/f /r)? If not, how do I schedule it to make a full scan? thank you!
  3. Posts : 72,043
       #102
    Hello Rookie,
    If you like, you could also manually run the command from a command prompt at boot whenever you like. Just be sure to use the correct drive letters since they are not always the same at boot as they are in Windows.
  4. Posts : 44
    Brink said:
    Hello Rookie,
    Thanks for replying! ok, How do I find out what's the drive letter for the partition I want to check?
  5. Posts : 72,043
       #104
    You're welcome.
    While in the command prompt at boot, you could type these commands below and press Enter after each one to see what the drive letters are for the volumes. You'll have to go by the label and size of the drive to help know which letter belongs to the one you want to run chkdsk on though.
    diskpart
    list volume
    exit
  6. Posts : 3
    Windows 7 Ultimate x86
       #105
    Hi all! :)
    Error-checking say after check on external hdd that repaired files now used by OS and old are puted to folder named "Found", i google it and everone saying that thay are in root folder, i can not find it i try search all my computer and still nothing, " Hiddin fol, and fil, are shown and so " Hide prot, fol, and files" . I also run Cmd with Admin right, try " dir e:\ still no folder named Found ! So far nothing, thanks and sorry if answer is on prev. pages i am reading it but left me few more to finish it. Great tutorial btw.
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Users\Peki>dir c:\
    Volume in drive C has no label.
    Volume Serial Number is 003F-B4B2
    Directory of c:\
    30.05.2013 22:46 <DIR> AeriaGames
    10.06.2009 22:42 24 autoexec.bat
    29.10.2013 14:13 <DIR> CFLog
    10.06.2009 22:42 10 config.sys
    26.10.2013 15:13 <DIR> Moje
    07.10.2013 20:32 <DIR> NVIDIA
    07.10.2013 18:29 <DIR> PerfLogs
    28.10.2013 18:38 <DIR> Program Files
    19.10.2013 05:06 0 requiem.log
    07.10.2013 18:54 <DIR> Users
    14.10.2013 14:44 <DIR> Windows
    3 File(s) 34 bytes
    8 Dir(s) 429.419.782.144 bytes free
    C:\Users\Peki>dir e:\
    Volume in drive E is New Volume
    Volume Serial Number is 6264-151F
    Directory of e:\
    30.10.2013 22:38 <DIR> Filmovi
    29.10.2013 12:55 <DIR> Igre
    21.10.2013 22:26 <DIR> Knjige
    28.10.2013 18:35 <DIR> Programi
    30.10.2013 22:38 <DIR> Serije
    21.10.2013 21:40 <DIR> Slike
    12.07.2013 20:37 <DIR> Tehnicki problemi
    30.09.2013 05:32 <DIR> Tekstovi
    26.09.2013 06:11 <DIR> Zika
    0 File(s) 0 bytes
    9 Dir(s) 453.423.325.184 bytes free
    C:\Users\Peki>
  7. Posts : 72,043
       #106
    Hello Sky90po, and welcome to Seven Forums.
    By default, chkdsk saves recovered files in a C:/found.000 folder. The 000 will increase by increments of 1 each time chkdsk is ran and saves recovered files if a previous folder exists.
    Look for this folder, or search for Found* instead.
    Hope this helps, :)
  8. Posts : 3
       #107
    Thanks but i do not have that folder.
    Whats story with this sn Volume in drive E is New Volume
    Volume Serial Number is 6264-151F and Volume in drive C has no label.
    Volume Serial Number is 003F-B4B2 , thats not my hardwer serial numbers ... ? My hardwer sn are other one not this one!
  9. Posts : 72,043
       #108
    I suppose it didn't create it then. Usually these recovered files are useless anyways though.
  10. Posts : 3
       #109
    What about Sn? And can you maybe know why os did not create that folder Found?
