#100
Cozzu,
Did it mention the name of the recent program you installed?
If not, then see if you may be able to boot to a command prompt at startup (boot) using OPTION TWO in the tutorial, to run chkdsk on the drive from there instead.
Note that the drive letters are not always the same at boot as they are while in Windows.
