Disk Check
Page 13 of 14 FirstFirst ... 311121314 LastLast
  1. mjf
    Windows 7x64 Home Premium SP1
       #120
    In addition to SeaTools the WD diagnostic tool is
    WinDlg
    You may want to run the Quick tests first.
  2. Posts : 5
    Hi Brink and mjf,
    I just ran WinDlg on my drive and it shows error code=07 failed read test element, failure 97 and based on WinDlg manual, it said read element failure and I have to RMA the HD. Fortunately it's still under warranty until 09/08/2014 so I guess, I will RMA it and get replacement from WD. Thank you so much for all the help.
  3. Posts : 72,052
       #122
    Sorry to hear that Anbu. Hopefully they'll get you a replacement soon.
  4. Posts : 3
    Hello this is the first post for me ever.
    I get something wrong here when I start this process, It was taking a lot of time and I cancelled it. That processing was on E.
    Then E doesn't want me to get in him. loooool.
    Please what should I do please?
  5. mjf
       #124
    Scan for and attempt recovery of bad sectors
    Will take a long time (1hour+ depending on the size of the HDD). The Seagate and WD diagnostics provide a quick check option. This doesn't substitute for a full scan but if they fail you'll know sooner that you have a problem.
  6. Posts : 880
    Windows 7 Professional 64bit
       #125
    I don't understand why, given after a crash Windows will give you the option to "Start Windows normally", that it doesn't also have some built-in way to prompt the user to do a Disk Check. I often end-up forgetting about the abnormal shutdown of Windows and the possible disk corruption that may have resulted.
    Does anyone here know of a method or utility that will enable me on bootup to select a Disk Check without having to go all-the-way in Windows and set-it-up manually and reboot yet again?
  7. Posts : 72,052
       #126
    Hello Max,
    You could open a command prompt at boot and run chkdsk using OPTION TWO in the tutorial. :)
  8. Posts : 880
       #127
    Hmmm what's the easiest way to "open cmd.exe at boot". I know there's a Repair thingie somewhere (maybe F8?) but now you have me thinking an EasyBCD menu item. Thanks for yr reply!
  9. Posts : 72,052
       #128
    It depends on what you consider easier, but you could take your pick below. :)
    Command Prompt at Startup
  10. Posts : 54
    Is it possible to run chkdsk on multiple drives?
    Whilst restarting Windows first - similar to running chkdsk on drive c:
    Last edited by sfwul; 20 Apr 2015 at 08:46. Reason: 2nd line last characters should have read: c: (instead of a smiley)
