Network Location - Set as Home, Work, or Public Network
  1. Posts : 72,046
    You're most welcome. :)
  2. Posts : 1
    windows 7 32 bit
    Wert said:
    I had to register just to write this =) :
    Actually there is a bug in windows 7 which prevent you from changing an "unidentified network" in some cases. I had this problem back in beta and RC and it's still there in the released version. Take a look here:
    Windows 7 RC - I can't change my network from public to work
    most helpful post IMO
    Also, posting a screenshot since you didn't seem to believe us, Brink.
    I was having problems with mine, as I used it to run internet connection sharing to my desktop temporarily, but a windows & avast update set me back yet again.
  3. Posts : 72,046
       #12
    Where did you get that from??? I never said or implied that.
  4. Posts : 542
    Windows 7 Pro 64bit
    so where do you recommend me setting it at on a college campus with more than 30,000 students and we all have our own username and passphrases to log on
  5. Posts : 72,046
       #14
    Hello Sean,
    It would be best to check with your college IT department to see what they say to use with their network. :)
  6. Posts : 18
    Windows 7 Pro 64-bit
       #15
    I know it's been a long time, but I have just come across this excellent topic!
    I'm a bit puzzled in the Registry Change method by your table (Option Three, point 6):
    Network     Data
    Location    Value
    Public      0
    Home        1
    Domain      2
    What happened about 'Work'?
    Inspecting my Windows 7 Pro machines which were all set to Work shows that the Category is set to 1.
    Should 'Home' in your table be changed to 'Private - either Home or Work'?
    Thanks!
  7. Posts : 72,046
       #16
    Hello John, :)
    You're correct. "Private" would be a better description since "1" will change it to Home or Work based on your Private network.
  8. Posts : 18
       #17
    Thanks, Shaun - I note that in some replies on 'other' forums the value 2 is assigned (erroneously) to Work, not Domain.
    Can you say what is the meaning of the value "CategoryType", which appears in some profiles, please?
    I thought this might distinguish between 'Home' and 'Work' networks, but it seems not.
    How can these be distinguished (in the registry)?
  9. Posts : 72,046
       #18
    Yeah, "CategoryType" doesn't get changed when switching network locations.
    I haven't found anything else to distinguish between Home and Work either for the registry, and why Option 1 is the preferred method to use.
  10. Posts : 18
       #19
    Thanks, Shaun - I was hoping to add something to assign network location to the end of a BATch file (which interchanges static IP addressing with DHCP, or vice versa), but it already looked a bit difficult. If you say it's impossible to distinguish Work network and Home network in the registry then I can stop right now!
