How to Open Folder in New Process in Windows 7 and Windows 8
This tutorial will show you how to open a drive, folder, or library window in a separate new explorer process in Windows 7 and Windows 8.
This is not the same as just having a folder open in a separate new window. Those two folder windows would still just be running in the same single explorer.exe process.
Having a folder open in a separate
process will allow multiple instances of the open folder window to be running with each instance running with a separate explorer.exe process. If one of these instances should close or crash, the other instances would be completely unaffected by it.
Warning
This can increase the stability of Windows 7 by opening every folder in a separate part of memory. Use this setting if your computer frequently crashes, and you are trying to minimize problems or troubleshoot. Be aware, however, that doing this could slow down the performance of your computer.
Tip
To see what processes (ex: explorer.exe) are running:
- Open Task Manager (CTRL+SHIFT+ESCAPE).
- Click on the Processes tab. (See screenshots below)
- Under Image Name, look for how many explorer.exe processes you have open. You will have one for each new folder process you open.
OPTION ONE
To Manually Open a Folder in a New Process
NOTE: This will allow you to manually open a selected folder window in a new separate process.
1. Press and hold the
Shift key, then right click on the drive, folder, or library that you want to open in a separate
process, release the
Shift key, and click/tap on
Open in New Process. (See screenshot below)
2. This will now open the selected folder in a separate window that is in a new process.
OPTION TWO
Turn On or Off to Launch Folders in Separate Process in Folder Options
NOTE: This will set Windows to always open all folder windows in a separate new process or not when they are opened.
1. Open Folder Options in
Windows 7 or
Windows 8, and click/tap on the
View tab. (See screenshot below step 4)
2. To Launch Folder Windows in a Separate Process when Opened
NOTE: Folders open in the same process as each other, but a separate instance to the process that provides the Shell.
A) Check the Launch folder windows in a separate process box. (See screenshot below step 4)
B) Go to step 4.
3. To Not Launch Folder Windows in a Separate Process when Opened
NOTE: Folders open in the same process as each other, in the same instance to the process that provides the Shell. This is the default setting.
A) Uncheck the Launch folder windows in a separate process box. (See screenshot below step 4)
4. Click on
OK. (See screenshot below)
OPTION THREE
Turn On or Off to Launch Folders in Separate Process using a REG File
1. To Launch Folder Windows in a Separate Process when Opened
Launch_Folder_Windows_in_Separate_Process.reg
B) Go to step 3.
2. To Not Launch Folder Windows in a Separate Process when Opened
Not_Launch_Folder_Windows_in_Separate_Process.reg
3. Save the .reg file to your desktop.
4. Double click/tap on the downloaded .reg file to merge it.
5. If prompted, click/tap on
Run,
Yes (UAC),
Yes, and
OK to approve the merge.
6. If open, close and reopen Windows Explorer (Window 7) or File Explorer (Windows 8) to apply.
NOTE: If you do not see a change, then log off and log on, or restart the computer to apply.
7. When done, you can delete the downloaded .reg file if you like. That's it,
