DPI Display Size Settings - Change
Page 4 of 4 FirstFirst ... 234
  1. Posts : 72,046
       #30
    Hello Phil, and welcome to Seven Forums. :)
    What application is this? Someone using the same may know a solution.
    Does the application have it's own settings for text size?
  2. Posts : 3
    Windows 7 Enterprise SP1
       #31
    Thanks Brink, the application is called Quintiq, its a unqiue application used for scheduling based on Java.
    No the application does not have its own settings for text size
  3. Posts : 72,046
       #32
    I'm not familiar with that program. If you haven't already, you might see if restarting the PC may allow the DPI setting to work in the program as well.
  4. Posts : 3
       #33
    Have tried restarting and also applying a Hotfix for DPI settings
  5. Posts : 72,046
       #34
    I'm not sure what else to suggest other than to do a system restore using a restore point dated when it did work properly.
  6. Posts : 1
    Windows 8.1
       #35
    You could try researching desktop resizing. I am using a TV as a secondary monitor and found that the taskbar was falling off the screen and adjusted it using desktop resizing. I was able to use the NVIDIA control panel.
