#40
No problem Arsalanronin. You can just remove the included folder in the library that you do not want to have show up. :)
I have some problems... I do not see the drop down arrow menu for setting time between each pictures. is there a way to fix that?
Thank You
Hello Morj, and welcome to Seven Forums.
What edition of Windows 7 do you have? The Windows 7 Starter edition does not have the Personalization feature included in it to allow you to be able to change the desktop background or to have slideshow. If you do have the Windows 7 starter edition, then you can use the free program in this tutorial below to be able to instead.
https://www.sevenforums.com/tutorials...7-starter.html
If you do not and the "Change picture every" menu is grayed out, then you will need to select (check) more than one picture for it to no longer be grayed out.
Hope this helps for now,
hello again,
I do not have the *Windows 7 starter* edition... Is there a difference between french and english version? I have the french one. Here is a picture of what it shows...
Thank You
Forget the last post i wrote, everything is O.K. and i don't know why. But I'm happy!
Hi there, For picture position I would like have my images centered. I know this might sound a bit odd but is there anyway to have centered images but have a background image instead of a background color? So the desktop would look like this:
And I notice that centering takes all screen space into account including the taskbar so the image doesn't sit completely centered. Is there anyway to center only in the screen space above the taskbar? Hope that makes sense. Cheers.
Hello Kiwichick,
Sorry, but no.
As a workaround, you could use Paint (mspaint.exe) and open the main background image (ex: blue one in your screenshot), then paste and center the other image on it and save this new combined image to use as your wallpaper with Fill instead.
Thanks Brink, Yes I know that. That's what I've been doing. But it's not so convenient if you have a whole folder of images you want to use. And then if I ever decided to change the background I would have to do them all over again. That's why I was hoping there would be some other way to do it.
