Send To Context Menu - Remove or Restore Default Items
Page 2 of 9 FirstFirst 1234 ... LastLast
  1. Posts : 5
    Win 7
    Expand DOCUMENTS folder
    Is there a way to expand the Documents menu from the Send To context menu?
    Attached Thumbnails Attached Thumbnails Send To Context Menu - Remove or Restore Default Items-send-.jpg
  2. Posts : 72,062
    Hello Mannee, and welcome to Seven Forums.
    Sorry, but not that I am aware of.
  3. Posts : 19
    Is it feasible to remove drives from the Send To context menu?
  4. Posts : 72,062
    Hello ksfno1,
    Yes, it sure is. You could use the tutorial below to remove all drives from the "Send to" context menu. :)
    Send To Context Menu - Remove or Show Drives - Vista Forums
  5. Posts : 1
    Windows 7 Enterprise
       #14
    Nice tip !
    Thanks for these tips. The Send Mail restore tip worked great. Thanks !
  6. Posts : 72,062
       #15
    You're most welcome Russell, and welcome to Seven Forums. :)
  7. Posts : 13
    Microsoft Windows 7 Enterprise SP1 64-bit
       #16
    Hi, these methods are working for me and the missing "Send To" shortcuts are restored. My issue is that they keep on disappearing after some random time and I have to keep on restoring them. The issue I have is always with "Desktop (create shortcut" and "Mail recipient" any idea what might be causing them to keep on disappearing from the SendTo context menu ?
  8. Posts : 72,062
       #17
    Hello Captain,
    Are you using any type of registry cleaning or other utility program before this happens?
  9. Posts : 13
       #18
    Brink said:
    Hello Captain,
    No I am not using any, it just disappears at a certain time.
  10. Posts : 72,062
       #19
    As a test, run a sfc /scannow command to see if it finds any corrupted system files, and is able to repair them if any found.
