Send To Context Menu - Remove or Restore Default Items
Page 4 of 9 FirstFirst ... 23456 ... LastLast
  1. Posts : 72,058
       #30
    What Send to options do you have?
  2. Posts : 7
    Windows 8.1
       #31
    Hopefully this screenshot attaches.
    Attached Thumbnails Attached Thumbnails Send To Context Menu - Remove or Restore Default Items-screenshot-14-.png
  3. Posts : 72,058
       #32
    Well, that looks good other than "Mail recipient" missing.
    Go ahead and post a screenshot showing both of your Sendto folders from Option One to see what they look like.
    C:\Users\Default\AppData\Roaming\Microsoft\Windows
    C:\Users\(your user-name)\AppData\Roaming\Microsoft\Windows
  4. Posts : 7
    Windows 8.1
       #33
    Here they are...
    Attached Thumbnails Attached Thumbnails Send To Context Menu - Remove or Restore Default Items-screenshot-15-.png   Send To Context Menu - Remove or Restore Default Items-screenshot-16-.png
  5. Posts : 72,058
       #34
    Yep, it's Thunderbird causing it. You can tell by the icon that you have for your Mail recipient shortcut instead of the default one.
  6. Posts : 7
    Windows 8.1
       #35
    So what can I do to fix it? Any ideas??
  7. Posts : 72,058
       #36
    Check to make sure that Thunderbird is set as the default program with all of it's associations.
    https://www.sevenforums.com/tutorials...ociations.html
    If that doesn't help, then other than selecting to attach the files from within Thunderbird, you might see if uninstalling and reinstalling Thunderbird may help.
  8. Posts : 7
    Windows 8.1
       #37
    It is set as the default program. I actually have already uninstalled and reinstalled, which didn't help. That's why I am so stumped!!
  9. Posts : 72,058
       #38
    If you only uninstall Thunderbird, does it work properly afterwards?
  10. Posts : 7
    Windows 8.1
       #39
    I did not try that. I really don't want to uninstall again because even though I had a MozBackup, it was a lot of work to get everything set up and working again. Shoot!
