BitLocker Drive Encryption - BitLocker To Go - Turn On or Off
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 72,050
    Ok. Thank you for sharing your results Warfare. :)
  2. Posts : 12
    sorry... maybe this is a dumb question, ermm... can we re-lock the encrypted drive in on-the-fly without system restart/logoff? if can, can someone show it off?
  3. Posts : 384
    Windows7
       #12
    Not a dumb question. I seem to recall MS themselves elsewhere recently expressing surprise there wasn't an explicit command, and indicating they looked to add it. It's a security risk that you can't readily re-lock a drive as easily as you can perform other functions.
    In the meantime, you can do the following via an elevated command prompt. You can also make it a .bat file that you simply run as an administrator.
    The command to lock drive d: on-the-fly would be:
    manage-bde -lock d:
    There's a space after "manage-bde" and after "-lock".
    More similar Bitlocker command line things are at the following should there be need:
    http://technet.microsoft.com/en-us/l...13(WS.10).aspx
  4. Posts : 12
    woahhh! there is actually eh... many thanx poin2!...
    this is wud i'm looking for , if there got something like just a button to lock/unlock the drive it would be just nice M$... =)
  5. Posts : 12
    another question for bitLocker, can we somehow encrypt just any folder in any hdd in our computer with BitLocker?
  6. Posts : 72,050
       #15
    Hello DeadGoat,
    You cannot do so with bitlocker since that is only for storage drives. However you can encrypt a file or folder just like Vista in Windows 7 though.
  7. Posts : 12
    thanx Brink... tried that before, its just i'm not feels the "secure sensation" with this method... maybe bcoz its doesnt have lock/unlock feature to open the file or folder that we encrypted
  8. Posts : 72,050
       #17
    Yeah, I would prefer to use BitLocker on a drive or BitLocker to Go on a USB key instead.
  9. Posts : 1
    w 7
       #18
    thx you
  10. Posts : 72,050
       #19
    You're welcome Hacker, and welcome to SevenForums. :)
